1 - 4 of 4 Posts
Hello eveybody i'm new to the site. I've recently purchased a chatter box alarm system for my 05 r1. After connecting everything on the alarm to the bike, and re-assembling I found that the bike doesn't start. The alarm works perfectly and was connected correctly. The bike turns on and all is well. Upon cranking the engine, it turns over but doesn't start...
The engine trouble light stays on and two digits: 30 are displayed in the left corner. I know this is an error code. But if anyone has had similar problems or maybe knows where i can find the meaning for this code it would help....thanks
Error Code 30 on Yamaha's is LEAN ANGLE CUT OFF SWITCH. It will shut off your fuel pump relay controlling your pump and injectors. Check your tip over sensor. You either forgot to plug it back in, or you messed it up.
1 - 4 of 4 Posts
