1 - 3 of 3 Posts
ZRO BLNG
Anyone have recommendations on which coolant to use?
I live in a hot weather climate, (70-90 degrees daily), and was wondering if any product was recommended or better than just using plain ol' water and coolant.
Thanks.
I just use Prestone (or similar) and distilled water. Make sure that the coolant you use is OK for aluminum radiators. You might want to look into adding some Water Wetter or Engine Ice if you think you need more cooling, but a 50/50 mix of coolant and water (distilled) should be fine.
ZRO BLNG
Discussion Starter #3
I've heard of Engine Ice. More cooling couldn't hurt. Especially here in Hawaii.
1 - 3 of 3 Posts
