1 - 4 of 4 Posts
My 2002 Ducati Monster 900 i.e. is starting to stall whenever I'm not on the throttle. It seems to happen whenever it gets above a certain temperature (240 degrees or so) and has even happened in high gears (at 70 mph) when not using the throttle.
When I come to stop lights, etc, if I use the choke, it will keep the engine running. Not sure if this is a case of overheating or if it's got something to do with the flow of air or fuel into the manifold. Any ideas about the problem are greatly appreciated...
· old member
At what engine speed is your idle set? It should be about 1200 rpm. If too low, the engine will have a tendency to stall when you pull in the clutch.
240 degrees F sounds quite high. Your fan should come on well before that at maybe 225.
1 - 4 of 4 Posts
