Back in stock:
Q/R Metal Fuel Connector: Female
$23.95
Q/R Metal Fuel Connector: Male
$23.95
Theses fitting are made from chrome-plated brass. Replace the fragile OEM male/female plastic fuel connector with strong, fail proof metal one. The OEM unit is very fragile and brakes off easily under heat and pressure and can cause a breakdown while on the road. The original unit may also cause a fire, resulting in a total loss of the vehicle.
Very Important: Does not fit the 748 with the non-adjustable steering head, or 749/999 or 848-1198 Models. For the 1199 use: Q/R Metal Fuel Connectors: Ducati 1199 Panigale
Connectors are sold each (most applications require 2 female and 2 male)
Note: This connector is not compatible with the OEM plastic connector, for use with the metal male Q/R fuel connector only
