CDT Carbon Fiber Rear Hugger: 748-998
$333.95 FREE Shipping
Protect your expensive rear shock from rocks and abrasive dirt. This rear hugger incorporates a chain guard, a dimple for exhaust clearance and integrated brake line cover. Available in polished or clear coat finish.
For Superbikes that are running taller than OEM tires or for those that have shortened the swingarm by adjusting the rear eccentric toward the engine, the exhaust dimple may rub the rear tire. You may need to run spacers to push the up rear hugger or adjust the rear eccentric away from the rear hugger (usually the 4-5 o'clock position).
NOTE: Pre-preg Carbon Fiber parts use less resin because it is "cooked" under pressure which results in a stronger and lighter product than typical wet-lay up Carbon Fiber. Pre-preg is the preferred method for racing, and aerospace. It is more expensive to build with this method but it results in a superior product.
