MW Tuning Low Temp Fan Switch: Ducati 748, 916, & 996
$69.95
The correct fan switch to lower the operating temperature of your Ducati.
OEM: Fan turns on at 197°, fans turns off at 188°
MW Tuning Switch: Fan turns on at 179°, fan turns off at 152°
The idea with this switch is to keep your fan on as much as possible in the normal operating range to ensure no chance of over heating, but unlike manual fan switches this will ensure your fan is always turned off when the bike is off.
This kit includes the switch, new crush gasket, and 2 spade fittings.
This kit will require you to clip off the OEM plug, strip the wire, and crimp the wire into the new spade fittings.
Switch is made in Italy
