Ducabike Clear Clutch Cover Engine Case
Was: $799.99
Sale: $749.99 FREE Shipping
Ducabike Ducati wet clutch case cover with clear clutch cover. This is a very unique item that is only manufactured by Ducabike. CNC machined from a single block of aluminum then anodized. Choose between a silver or black case cover and then your choice of clutch cover ring color. The leading edge of the outer cover will protect the Plexiglas cover from breaking in the event of a fall. This kit includes all the hardware needed and no modifications are required to install.
This kit does not include the wet clutch pressure plate ring #CCDV01SM seen inside the clutch. It is available separately as it does not fit all models that the clutch case does. For the Multistrada 1200 you will also need to purchase #CCDV01R, which is a support bracket for the lower cowling.
optional:
Ducabike Ducati Wet Clutch Pressure Plate Ring
Pricing: $49.99
Optional wet clutch pressure plate ring CNC machined from aluminum and anodized in your choice of color when using the Ducabike we clutch case cover #CCDV01D or #CCV01E
* Register on the Motowheels website for Free forum or lifetime VIP passwords to access discounts on most non sale items. Look for memberships and choose the membership type that fits you the best
