1 - 5 of 5 Posts
Hey guys! I have a 2003 kawi Z1000.
So I winterized it properly, but my battery tender got bumped by someone in the garage and came off. So the battery has been dead for who knows how long.
Anyways, I recharged the battery and tried to start it last night.
Key on it does the normal flashing lights on the dash, hear the fuel pump whine, then hit start button and it just cranks and cranks and cranks.
All fuses under seat look good. Are there fuses else where?
Battery connections are tight.
It has a power commander 3 if that makes a differnce.
So any ideas?
Bypass the PC and try it? Can you tell if it's getting fuel and spark? Check the basics.
How do I bypass the pc3?
And it was running fine 2 weeks ago. Nothing has changed, bike has not even been moved other then the battery being taken out.
But I can check the spark this weekend.
the joke is in your hand
how slow does it turn over? power commanders and modern computerized bikes need a good battery to be able to start. even if it does turn over the engine is no longer a guarantee it will start.
power commanders are also known for not properly energizing when the battery is weak.
1 - 5 of 5 Posts
