CORSE DYNAMICS Wheel Nut Socket: 748-998/S2R-S4R/HM/848/MHE/M796-1100/MTS1000-1100/SF848
Pricing: $59.95
This dual sided tool was specifically designed to work with OEM Ducati nuts, billet aftermarket nuts, Titanium Nuts, 6 point Nuts, or 12 point Nuts. This is the only steel tool on the market that has been made to work with all nuts on the market.
41mm on one side and 46mm on the other. 1/2 drive and treated so it can be used with impact tools. Unique lowprofile design and raised center keeps the tool from slipping off the axle nut when tightening.
Dual sided nut is more effective and less expensive alternative to multiple sockets.
Fits: Small axle Ducati single sided swingarm: 748-998/848/MTS1000/1100/Hypermotard/S2R/S4R/S4RS/M796-1100/Mhe/SF848
The pictured item is coated in an impact safe black coating.
CORSE DYNAMICS Wheel Nut Socket: 1098/1198/MTS1200/Streetfighter/Diavel/1199
Pricing: $59.95
This tool was specifically designed to work with OEM Ducati Nuts, Billet Aftermarket Nuts, or Titanium Nuts. This is the only steel tool on the market that has been made to work with all nuts on the market.
A standard socket will not fit properly on your 1098-1198-Streetfighter and MTS 1200 wheel nut. This is because the large axle nuts on the 1098-1198-Streetfighter, have a special inner taper. This tool is designed to fit perfectly and not ruin your wheel nuts. The low profile and locator built into the socket keeps the tool from slipping off the nut when tightening and possibly damaging the nut or your wheel.
* Register on the Motowheels website for Free forum or lifetime VIP passwords to access discounts on most non sale items. Look for memberships and choose the membership type that fits you the best
