CORSE DYNAMICS Rear Brake Caliper Bracket (84mm mount Brembo): Sport Classic, GT1000, Paul Smart
$229.95
Corse Dynamics has engineered a under swingarm bracket allowing use of the Brembo dual piston rear caliper. Performance is greatly improved over the stock single piston sliding caliper, including a substantial weight reduction.
Priced at nearly half the price of the other clunky designs using proprietary calipers. Corse Dynamics specifically designed this bracket to work with all Brembo 84mm mount rear calipers.
Price does not include rear caliper, a caliper can be added as an option for an additional cost. If you choose to not purchase the caliper, you will need one caliper & possibly a brake line depending on the caliper you purchase.
*Some models may require a custom brake line for installation.
Rear Caliper choices:
BREMBO Hard Anodized 84mm Mount CNC 2 Piece Rear Caliper
BREMBO Rear Caliper - 32mm 32G Piston
BREMBO Rear Caliper - 32mm Piston
BREMBO Rear Caliper - 34mm Piston
