CORSE DYNAMICS Magnetic Oil Drain Plug V2: Testastretta
Pricing: $22.95
Corse Dynamics oil drain plugs are a great way to upgrade your Ducati with a part that is both beautiful and functional!
• Our "double hex" design allows you to remove or install these plugs with either the factory tool OR an ordinary wrench or socket.
• Our plugs incorporate a Viton O-ring to ensure proper sealing against the engine. This provides a good seal every time
• Our plug comes pre-drilled for safety wire on all six faces. Our plugs include a rare earth magnet to collect any metal bits that might be inside your engine, our magnet is rated at six times the strength of other competing companies.
• Made in the USA.
New feature of the Version 2 (V2) drain plug, we are the only company to broach the allen key in the drain plug to ensure ultimate strength, this manufacturing process is often over looked because of high tooling cost versus milling a hex with 6 drilled holes on the end. Those 6 holes leave weak points in the hex that are prone to failure with thin wall aluminum.
CORSE DYNAMICS Magnetic Oil Drain Plug V2: 22mm
Pricing: $18.95
New feature of the new Version (V2) drain plug, we are the only company to broach the allen key in the drain plug to ensure ultimate strength, this manufacturing process is often over looked because of high tooling cost versus milling a hex with 6 drilled holes on the end. Those 6 holes leave weak points in the hex that are prone to failure with thin wall aluminum.
* Register on the Motowheels website for Free forum passwords or lifetime VIP passwords to access discounts on most non sale items. Look for memberships and choose the membership type that fits you the best
