CORSE DYNAMICS LED 7 inch Headlight Kit: Monsters & Sport Classics
$499.99 FREE Shipping
Fits all first generation Ducati Monsters and Sport Classics with some modifications. The perfect solution for your Ducati.
Kits includes:
• Gloss Black Powder-coated headlight bucket
• MW Custom LED headlight 7 inch
• Billet black anodized bracket
• Hardware
• Instructions for installation
Easy install takes about 20 minutes. This kit gives you a more modern high output LED headlight lens while retaining a vintage look with the headlight case. You will need to re-use your factory wiring for your headlight. The bracket mounts to your lower triple clamp where the factory mount currently mounts. You will remove the U-shaped bracket with mounts and headlamps. You will need to either remount your turnsignals somewhere or use a Oberon bar-end turnsignals kit.
When properly mounted, exceeds FMVSS-108 and CMVSS-108 DOT requirements for low beam and high beam performance.
Metalized reflector optics provide a lighting experience that's smooth and clean across the driving surface.
Provides a brighter, crisper and whiter light output, closer to the color temperature of daylight, dramatically improving light projection distance and overall visibility
Durability and dependability of LED lighting provides a solid-state, bulb-free headlamp design that impervious to damage from shock and vibration.
Military grade, die-cast aluminum housing and non-yellowing, polycarbonate lens offer optimum protection against damage from impact, roadside debris and other hazards.
Electronics are sealed in epoxy to resist from damage caused by corrosion or moisture.
Advanced circuitry protects against voltage spikes up to 600v.
Uses standard, H4, 3-blade wiring connector
Includes a 3-Year Limited Warranty
* Register on the Motowheels website for Free forum or lifetime VIP passwords to access discounts on most non sale items. Look for memberships and choose the membership type that fits you the best
