CORSE DYNAMICS Adjustable Reinforced Fuel Tank Bracket: 848, 1098, & 1198
Price: $99.95
Sale: $69.95
This adjustable bracket is the perfect remedy for fitting swollen gas tanks and is also substantially stronger than the factory bracket which tends to bend and shear.
With nearly 3/4" of adjustment
The factory .050" thick steel bracket is not adequately braced for side impact from tank movement, though this is common when riding a motorcycle.
Install note:
Some subframe mounting holes are slightly wider or narrower. The original equipment bracketis flexible so it does not matter but our billet mount does not flex so the subframe holes may have to be slotted with a file in order to fit this bracket.
* Register on the Motowheels website for Free forum passwords or lifetime VIP passwords to access discounts on most non sale items. Look for memberships and choose the membership type that fits you the best
