1 - 9 of 9 Posts
i got a busted fork seal, what can i use to get the fork oil/grime off my rotor/lower fairing? soap and water cleans it but not very well, any kinda degreaser or anything?
Discussion Starter · #6 ·
goo gone works a little, but i still gotta scrub it pretty good. ill try honda polish too. maybe ill just put soap/water/goo gone/honda cleaner/and castrol degreaser in a bucket and use that concoction. :headbang
fork oil on the rotor is not good, that means it's in your brak pads as well. I would use brake cleaner to get the fork oil off. when you get a new seal, i would clean the rotor and caliper real good with brake cleaner and change out the brake pads cause fork oil will soak into the pads.
1 - 9 of 9 Posts
