Hi, i was wondering the manual say's to check it after you let it run for 3 min and then let it sit for 3 min, if I do this the oil is right at teh full line, if I let the bike sit for awhile ( days) I check it and it has the hole sight glass filled up. I was wondering if I shopuld let it sit for afew days and then drain it down intill it is at the full line .Thanks alot
Already Sick of Winter
no. the reason the oil is above the fill line after it has sat is because all the oil has settled in the bottom of the pan.
if you follow the directions and the oil is at the right level you are fine.
