1 - 16 of 16 Posts
Some bike batteries can handle a 10 amp charge. My battery has the charging apmerage and times on the battery. it says .9 amp for 5-10 hrs. or 10 amp for 1hr. I bought a 1 amp charger for 20 bucks at shucks. If your battery doesn't say it can handle a 10 amp load just use a trickle charger. trying to charge it too fast can cause a a fire or explosion and can destroy your battery.
I use a Vector Smart Charger. It has 10 and 2 amp settings and senses what the battery can handle. On the smaller batteries I set it on the 2 amp setting. On the larger bike batteries, like in my Yamaha FJ600, I use the 10 amp setting and the charger usually starts off with about 4 amps, tapering off to 0.1 amps near full charge. I would like my next charger to have a 4 amp setting.
Walmart sells a battery tender for motorcycles for 18 dollars.
Silent pipes take lives
As above, some batteries can handle it. But the lower the charger's peak amperage, the safer it'll be, with the 2-amp-and-below range being generally safe for all motorcycle batteries.
If that's the black and decker one, don't buy it. I bought one, used it once or twice, then ~6 months later tried to use it again and it was fried. It would keep clicking back and forth detween charge and float, but at a machine-gun rate! I searched the net and found alot of people with the same issue, and they all said it worked fin for a month or two, then did what mione did.
I wouldn't buy anything other than Battery Tender brand. $30, I have 3 of them and use them constantly for all kinds of batterys!
1 - 16 of 16 Posts
