Hi;
Anyone have recommendations on any particular chain lubricant and cleaner? Does it matter?
Service manual says to use kerosene to clean, and a lubricant, but doesn't mention specific brands - so I'm assuming any brand will work? Agree?
YZ6 Service Manual:
LUBRICATING THE DRIVE CHAIN
The drive chain consists of many interacting
parts. If the drive chain is not maintained properly,
it will wear out quickly. Therefore, the drive
chain should be serviced, especially when the
vehicle is used in dusty areas.
This vehicle has a drive chain with small rubber
O-rings between each side plate. Steam
cleaning, high-pressure washing, certain solvents,
and the use of a coarse brush can damage
these O-rings. Therefore, use only
kerosene to clean the drive chain. Wipe the
drive chain dry and thoroughly lubricate it with
engine oil or chain lubricant that is suitable for
O-ring chains. Do not use any other lubricants
on the drive chain since they may contain solvents
that could damage the O-rings.
YZ6 Service Manual:
