BREMBO Mechanical Brake Switch: GP Master Cylinder
$69.95
If you have ever used a pressure switch in your brake system you know they don't work until the brake lever is nearly touching the bar, this mechanical system solves all of the failed performance seen with the pressure switch.
Utilizing a Brembo micro switch and CNC machined components this kit allows use of a mechanical switch on your aftermarket GP master cylinder.
Kit installs very easy by removing the factory lever pivot and replacing with this pivot and switch assembly, dial in the exact engagement via the adjustable pivot and your ready for years of safe brake light actuation.
