BREMBO GP Master Cylinder Mechanical Brake Switch kit by Corse Dynamics
Pricing: $69.95
If you have used a pressure switch in your brake system you know they don't work until the brake lever is nearly touching the bar - and if you have that pressure switch on your bike for a number of years, you might notice it is getting slower or inconsistent.
This mechanical system solves all of the failed performance seen with the pressure switch.
Utilizing a Brembo micro switch and Corse Dynamics CNC machined components, this kit allows use of a mechanical switch on your aftermarket GP master cylinder.
Kit installs very easy by removing the factory lever pivot and replacing with this pivot and switch assembly, dial in the exact engagement via the adjustable pivot and your ready for years of safe brake light actuation.
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items or lifetime VIP passwords for deeper discounts on all items. Look for memberships and choose the membership type that fits you the best
