1 - 7 of 7 Posts
Hey guys i'm new to the bike world. I'm having an issue with my hyosung 250r. The Bulb in the brake light keeps burning out on me i thought it might be because of wiring from when i upgraded my rear turn signals. But those are all good. Any other ideas on where i should look. O and the fuses in the rear haven't blown either. are there fuses somewhere else that may have blown
could be vibration, mabe something is lose, does the bike have a batt? usualy the batt acts as a voltage catch so to speek, so everything elce doesnt get over voltage from the stator. so mabe make sure the termanals are good and tight. another option is put an let type replacement in it,
· old member
If this starting happening at exactly the same time as your turn signal changes, that's where to start. What exactly did you do to "upgrade" your turn signals? Wiring changes?
If your getting over 14.5v to it that'll do it, or could be vibration, OR common problem in cars, people touch the bulb with their bare hands and get their oil from their skin on the bulbs which make them blow quick. Just get some led's and be done with them
1 - 7 of 7 Posts
