1 - 9 of 9 Posts
i am getting some Galfer ss brake lines and i need to bleed the brakes, that is not problem but do i need to flush the system with anything or am i all good to just put in the new dot4 fluid?
yeah parents have an air compressor so i was going to clean them all out before using them.
RESIDENT ASSHOLE
you dont use an air compressor............
just bleed new fluid in.
RESIDENT ASSHOLE
Dude you use an air compressor to clear out a caliper and youll blow the pistons out of it.
Most people cant take a caliper apart and put it together without making a big leak..........
Clean fluid is fine, the fluid will get dirty almost immediately anyways and it absorbs moisture from the air as well.
Brake fluid is hydroscopic meaning it is really attracted to water and will pull it from anywhere it can. Old brake fluid (6 months) should be discarded IF THE TOP HAS BEEN POPPED.
RESIDENT ASSHOLE
Thats why Im here!
1 - 9 of 9 Posts
