Just a few quick questions ....
I'm slowly starting to do more and more of the maintenance myself ….. bear with me, I’m still pretty new to this
. I was able to lube up the clutch cable but the only way I was able to do it was by removing the clutch lever to get to the end of the cable so I could put the lube clamp on it. Is there an easier way to do this or is that about it for the clutch.
Is there an easy way to lube the throttle cables?? To me it looks like the only way it to take apart the grip assembly to get to the ends of the cables.
Also, what’s the correct way to check your idle speed?? If I start the bike up and let it run for a bit, say 5 minutes, the idle speed is lower then specs. But if I take it out for a spin the idle speed is right in specs. So which reading is more accurate??
And any other maint tips ya wanna leave feel free to ….. Only thing I know I’m good at is oil changes and chain maint so anything would help.
