1 - 12 of 12 Posts
The bike accidentally fell while sitting still while it was running, i picked the bike up and now it wont start, it would just crank.
its a 99 gixxer600, any help or ideas?
~ Master Technician ~
Its most likely the tip over switch. Find it and then tap on it a few times.
It's carb'd, it happens. Happened to me doing an endo. All that happens is you flood it. Give it a little, and try again. Just try and start it, without giving any gas (theres already enough in it). It'll kick over shortly.
tip over switch/sensor gets my vote
If you activate the Tip-Over Switch most bikes require the shutoff of the kill switch and removal of the key to reset the Switch. Try that...
Discussion Starter #11
Thanks for the replys guys, I let it sit there for a few hours since I needed to replace the battery after that. then it craked back up.
Ill check the air box today for any oil... should the bike be finenow? it seems to be running good.
1 - 12 of 12 Posts
