1 - 12 of 12 Posts
Mediocre Strafer
Here's the deal - most aftermarket SS brake line kits use two near-equal lines run directly from each caliper to the MC, so I've never had a choice to make before. However, I'm looking at Hel lines, and for my ZX-14 they have three different line configurations available:
1) The aforementioned two line direct MC-caliper configuration
2) The stock configuration, which is a single line MC-right caliper, and a second over-the-fender line to the left caliper
3) A "Y" configuration, single line MC-junction block, then two short lines to either caliper
Now, theoretically, it shouldn't matter how you run the lines; thanks to the miracle of hydraulics the entire system sees the same pressure. In the real world; however, I'm thinking that configuration 2 may be preferable, simply because it provides the shortest total hose length; so whatever percent of expansion there is will occupy less volume/travel. It also has the advantage of simpler hose routing since I can use all the stock mounting points.
Comments, opinions, dirty remarks? :eatpop
KeS
That splitter in the stock set-up and the Y set-up is what I try to eliminate. My experience has been that they can trap air and can be difficult to bleed. Also, with the splitter or Y, you have more connections...more possible leaks/problems.
I believe the best set up is a dbl-banjo at the MC and separate line to each caliper.
You should use what you feel most comfortable with.
The double banjo @ the MC is incredibly easy to bleed - when I put my lines on, it probably took 20 minutes of total bleeding time (for both lines).
OO=[][]=OO
I have 'y' fitting a behind the headlight and two symmetrical lines running down to each caliper. They came SS from the factory so i have no plans to replace them. i would however prefer the two lines off of the MC. fewer parts, fewer seals. my least favorite, for aesthetic reasons, is the one line down and one over the fender. I like symmetry.
Mediocre Strafer
Discussion Starter #6
Well, it's true my bike turns right better than left, and I'm sure the asymmetric weight of the stock line setup is why, so I'll take that into account. :eek:nfloor
Tx for the feedback, guys. I'll report back once I've installed whichever lines I get.
KeS
OO=[][]=OO
KeS
it's not so much the weight as it is the extra wind resistance. i hear at ~600mph it will cause the bike to veer to the right slightly. it's definatly a safety issue you should be concerned about :lao
the joke is in your hand
do the 2 line deal. it's easier to install and less hoses etc..I've read in a mag this is the prefered method of installation for racing applications. can't remember why, but it does (as they said) make a difference. I think it was something to do with being more of a direct link to the caliper. (don't quote me).
all bike brakes carries all the different layouts of brake lines i got the 2 line race style i think its the most simple kit to use and install. check it out here is the link i also purchased the HEL brake line kit they seem to bee a little better looking then the rest and are D.O.T approved. All Bike Brakes - Motorcycle Brakes and Brake Lines Custom brake lines
So...what did you put on?
Mediocre Strafer
Discussion Starter #12
A Hel three-line kit that follows the stock hose routing for the ZX-14. That was more important to me than running double-direct lines. Everytime I get away from a stock configuration I just run into hassles - in this case it would have been that there's not enough clearance at the MC to install a double banjo without slamming the bolt into the tank at full lock.
KeS
1 - 12 of 12 Posts
