1 - 3 of 3 Posts
Hi folks I have a 07 fzr 600s with a brand new battery without driving the bike the battery will completely drain over 2 days any ideas would be appreciated thank you
Could be grounded somewhere. I'd start by getting a multimeter, setting it to ohms, putting positive lead on the positive battery and negative lead on the frame, if youre getting a reading, that means its grounding on the frame.
Any electrical accessories installed? Some things draw current even when off or un-plugged. Powered tank bag rings are notorious for this.
I'd suspect anything directly connected to the battery first. After that, look for relays that are warm/hot when the bike is off. A stuck relay will draw power in some cases. Horn, lights, etc.
Google "how to check dark current" if you have a multimeter.
1 - 3 of 3 Posts
