Are the carbs on a 1992 ZX7R engine side draft or top draft ? I found a replacement engine for my 1990 ZX7R aka ZXR750. I found specs on both engines but no specific details on carbs. Fortunatley the seller is giving the harness and a few other parts all for $425. Engine has 12800 miles. I'll replace the seals before installing even though owner claims no oil leaks.
Thanks for the advice.:)
SeedyROM
The carbs on the 927r are Keihin flat slide downdraft carbs. The R's also had hot cams, close-ratio tranny, magnesium clutch and side cover, hotter cdi, and higher comp. pistons.
