1 - 9 of 9 Posts
I'm experiencing some odd, inconsistent problems with accessing sportbikes.net. I have connections inside and outside my company's proxy. Inside the proxy, can't reach the site. Errors as if I've typed in some bogus domain name.
Disconnect from the internal LAN - fire up the external WIFI, which is outside the proxy, and I STILL can't reach the site. Same conditions.
Walk over to a machine physically connected to the same Ethernet segment the WIFI NIC was associated to, no problem. Things work fine. Was browsing the site normally up until about 9:45am Central.
Can ping the server on the physically connected external machine.
Cannot ping on the WIFI, same segment. Very strange.
retired from here
interesting but i have not had any problems for the past few days other than it gets slow at times but i think that is more on my puter than anything else.
Super Moderator
I have not been able to log on to SBN from work for the past week. I think they blocked it.
hmmmm....Strange, been working great for me. In fact, it has been running the fastest I ever seen it run, because it seems to be running so fast, I figured Fred and Ducman must have finally got rid of some dead weight.
Discussion Starter · #7 ·
My ISP at home also can't resolve the "sportbikes.net" name. So, that makes my Internet connection at work and at home that can't reach this server. I'm dialed into a free NetZero accont right now and as you can see since I'm posting...no problem. I'm checking another ISP later today.
Iwonder if there have been any DNS changes/problems lately.
Discussion Starter · #8 ·
Something is afoot at the network layer.
C:\WINDOWS>ping sportbikes.net
Pinging sportbikes.net [64.246.62.108] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 64.246.62.108:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Neither my home nor work subnets can ping sportbikes.net. If I configure my web browser at home to use some arbitrary anonymous proxy I can reach the site just fine. There is some access control at play here on the server and/or the provider's network. Fred will be away for the next few weeks so I'll just have to proxy my access at home and go without while at work, as I can't proxy there.
Discussion Starter · #9 · (Edited)
Tracing route to sportbikes.net [64.246.62.108]
over a maximum of 30 hops:
1 10ms 10 ms <10 ms 10.20.0.1
2 10 ms <10 ms <10 ms 10.10.0.1
3 10 ms <10 ms <10 ms 206.195.192.129
4 <10 ms <10 ms 10 ms 206.195.193.5
5 * * * Request timed out.
6 10 ms 10 ms 21 ms 12.118.186.61
7 20 ms 10 ms 11 ms gbr6-p80.cgcil.ip.att.net [12.123.5.222]
8 10 ms 10 ms 10 ms 12.123.216.217
9 20 ms 10 ms 20 ms 12.119.137.50
10 20 ms 10 ms 20 ms so-1-0-0.cr1.ord2.us.above.net
[64.125.30.146]
11 30 ms 30 ms 40 ms so-5-0-0.cr1.dfw2.us.above.net
[64.125.30.249]
12 30 ms 40 ms 40 ms so-3-3-0.mpr1.iah1.us.above.net
[64.125.29.21]
13 40 ms 40 ms 40 ms 216.200.251.53.ev1.net [216.200.251.53]
14 40 ms 40 ms 40 ms ivhou-207-218-245-113.ev1.net
[207.218.245.113]
15 * * * Request timed out.
Again, can proxy a connection here but direct connections from home/work are being blocked. Networks that cannot reach sportbikes.net:
206.195.192.0/24
206.195.193.0/24
216.114.214.0/23
1 - 9 of 9 Posts
