1 - 5 of 5 Posts
Here's some specs. Any type kind of motorcycle battery that fits the dimensions and voltage capacity and minimum amperage will work, but you can use this info to get a replacement depending on what is available in Colombia.
Yamaha - FZ6 2004-2005 600cc
Battery Family: Maintenance Free Battery
Type: YT12B-BS
Voltage: 12
Capacity: 10
Dimensions: 6" x 2 3/4" x 5 1/8"
Weight: 7.6 lbs.
Metric Dimensions: 150mm x 69.0mm x 130.0mm
Metric Weight: 130 kg
Polarity:
Acid Volume: 0.50
Amps: 1.0C.
C.A.: 125
1 - 5 of 5 Posts
