One last ABM rotor--perfect for single rotor conversion for light weight projects.
ABM Floating Front Rotor (Ducati 6 Bolt 10MM Offset): MON, ST, SS, Sport Classic, 851/888, 748-998
Was: $329.95
Sale: $199.95
The edges of the v-formed heat pockets enable optimum cleaning and removal of dampness from the pads. Together with its CNC milled aluminum inner ring it is one of the lightest brake discs on the market today. Outer Ring Curved contours and recesses optimize self-cleaning and ensures equal wear of the brake pads. The special shape provides maximum surface area which eliminates deformation even at extreme temperatures. Floaters enable axial movement of the external ring allowing expansion and contraction of the brake disc without deforming.
320mm diameter full floating design
This rotor is discontinued, we only have one rotor (single rotor) available, perfect for a monster or single rotor conversion
