Pictures by JonD82 - Photobucket
pics of everything im selling..
All Parts are located in Mount Pleasant MI
Ok I know im new here, I am selling on Ebay under jon101605 also seling on stunt forums. Look up JonD I am selling all over.
I have tons of stock OEM parts and after market parts..
03/04 - ZX6R 636 STOCK PARTS
Front Rim
Front Rotors
Front calipers Left and Right side
Front fender
Front axle w/spacers
Forks
Upper and Lower triple with neck
Ignition w/lock set
Clipons
Throttle tube
Throttle housing
Handle grips
Upper stay
Ram air tube
Headlight
Front brake lines
Ram air covers
Radiator
Radiator fan
Horn
Wire harness (complete with injector harness as well)
Left clipon switch pod (turn signal switch pod)
Right clipon switch pod (kill/start switch pod)
Gauge cluster
Mirrors
Upper Fairing
Left side mid fairing
Right side mid fairing
Tail fairing
Under tail fairing
Gas tank
Throttle Bodies
Engine
Air box
Air filter
Radiator reservoir
Stator
Rectifier
Kick stand
Main Frame
Sub Frame
Fuel pump
Front seat
Rear seat
Seat cowl
Battery tray
Trunk
ECU (computer)
Rearsets
Passenger pegs
Headers
Exhaust (after market ones available)
Rear brake master w/reservoir
Rear brake line
Rear caliper
Rear axle w/spacers and caliper bracket
Rear rim
Coil packs
Brake light (intergraded ones available)
Rear shock
Swing arm
Have other after market parts as well.
Power commander
Yoshi pipe
D&D pipe
Race stator cover
F4i Parts left
-Air box with stock filter
-K&N Air Filter
-Frame with Michigan Clean Title & bill of sale included
-Tail Fairing, broken perfect for a 12 bar
-Battery Tray
-Swingarm
-Front Wheel, no bends with rotors
-Front Calipers
-Stock Forks
-Upper Triple w/ Ignition w/ gas cap and trunk lock tumbler & key
-Front Fender
-Upper Stay ( slight tweek to it)
-Gauge Cluster
-Headlight Harness
-Intake Air Ducts
- Stock Clipons
-Leftside Control Switches
-Rightside Control Switches
-Stock Clutch lever w/perch
-Front Brake Line
-Rectifier
-Fuel Pump
-Stock Rear Sets ( only have right side left)
-Front Axle w/spacers
-Rear Axle w/spacers
-Rear Rim with rotor
-Rear Caliper w/bracket & Line
-Rear Shock
-Chain Guard
-Throttle cable
-Throttle tube
-Coolant Resevoir Tank
-Ohlins rear shock, with remote hydraulic preload adjustment
-Dan Kyle Racing modified forks (I have all the stock springs/guts from the forks for sale if anyone needs aswell)
-Attack racing fully adjustable triple clamps
-Moriwaki rearsets With shifter/brake lever
-Full titanium Moriwaki exhaust
-Full HRC wiring harness (no key needed) HRC instruments
-Dynojet power commander PCIII (have book and custom maps to go with it)
-Full set of Race Plastics for F4i (comes with cut to fit ram air covers)
-After market Clipons
-48 tooth sprocket
-Throttle bodies
-Head light (small crack in it)
-Stock Wire Harness for 01 F4i
-Extra Clutch lever
-Extra Front master Lever
-Extra Clutch Cable
-Rubbers are for sale aswell
Might have other stuff not listed will add as I find it. ( JUST GOT A 02 STOCK F4i COMPLETE BIKE IN YESTERDAY 9/6/2011) HAVE TONS OF STOCK OEM PARTS will add more photos to photo bucket as I get them
I HAVE TONS FOR SALE!!!
Got 2 frames for 300 each
Frame 1 = Left side lower mounting point for subframe broke off
Frame 2 = Left side mid moint in frame has a 3/4 hole in frame
Got 1 for 500 with a small dent on the left side no cracks or bends
ALL 3 FRAMES HAVE GREEN MICHIGAN TITLES! Clean and Clear!!!
I also have a mint condition clean and clear 636 frame 2003.
I have 2 great running 636 engines and another that might need work
also have 1 F4i engine with 18K miles on it runs perfect still in bike atm will take apart this weekend
Email me at : [email protected] if interested in anything I have or if your looking for anything. I get new inventory in often!
