1 - 4 of 4 Posts
250r battery into fz600?
Hi,
I'm looking at a fz600(forsale) with a dead battery.
Can I stick a 250r battery into fzr600 use to see if the fzr600 runs?
thanks,
mutsu
linuxbikr said:
You can try. Should be enough to see if it turns over. Or can try to jump the FZR's battery with your car battery.
If you jump it use small cables because if you use normal car jumper cables there is going to be way to much amperage running through your bike.
Car battery will most likely fry electrical system on an fz6, especially if car is running. Put bike in 2nd gear (first gear will not work) and have someone help you push it with you on it. Pop the clutch and keep on the gas once you've built up some speed, this should get the bike started. I've done it once before leaving my lights on like an idiot. Lesson learned the hard way!
1 - 4 of 4 Posts
