I have a 2006 yamaha fz6, left it sitting out in rain for like a week because my garage door wouldn't open manually or with the motor. Came back to start it and it started but sounded like it had a bad misfire and wouldn't stay on even with throttle.
Coil packs went bad. No spark on one of them. Replaced it, tried to start it and it would crank and I get spark, I have good spark plugs too, but it only made a small fire up and died right out, key off, back on and now I have like 5 different codes. 13. 14. 19. 30.42. Checked the lean angle sensor and kickstand sensor and they both come back within voltage spec so sensors are fine, wiring seems fine too leading to sensors, I believe it might be a bad ecu thats not firing the injectors.
