Hey y'all! Just bought this bike and get her home to find oil leaking from the exhaust flange. Doesn't seem to have as much response in the throttle while at speed. Using excessive amount of fuel for short trips and front exhaust (where it's leaking) doesn't seem to be getting hot.... Any suggestions?
Pull the spark plug for that cylinder and see what it looks like. Sounds like you're just pushing fuel and oil into that cylinder w/o it firing. Could be something simple, or more expensive. Pull both/all the plugs and compare, check the air box/filter to see if there are any obstructions inside, mouse nexts against the air filter, etc. If you know how, check for spark at the plug for that cylinder as well.
Don't post the same thing in different threads, it makes it harder for people to help out.
