1 - 5 of 5 Posts
Bike has never had an issue. This Saturday I noticed I had to push the pedal all the way to get it to hold still at a stop sign. I have bled the system a couple of times (including elevating the caliper above the reservoir). Both pistons move freely. Any ideas?
Deutsche Rüstungsteilung
The correct bleed is extremely important. Even after doing that I occasionally had a "free" rear brake pedal. Since I really didn't use the rear brake on mine it wasn't that big a deal, but the brick trick did work. Tie a brick to the rear pedal making sure it hangs below and above the garage floor while fully depressing the pedal. Leave it like that for 12-24 hours and it will work fine. I don't understand it, but it works.
Reactions: tex929rr
Thanks - it's in process. I really enjoyed walking though the house with a brick, telling my wife I was going to work on her Aprilia.
I had a 2003 R and the brick trick would last for weeks before it needed to be repeated. Let me know how it works out for you.
You can do that with the front brake too to firm it up a bit. Tie wrap the lever back
I heard it leaves the system open so all the air bubbles float up to the reservoir. Seems to work though. My rear brake has worked OK since I got it with no crazy bleeding procedures though. I primarily use our for slow speed maneuvering.
1 - 5 of 5 Posts
