hey guys, can anyone tell me what tools i need to take the front wheel off?
i found a little hex wrench in the tool pouch and took the little screws out but what size does it take to get the main one out?
TIA
It is a 12 MM Hex. Mine has an H12 marked on the side. I also got a Torque Wrench to make sure I did it right. Loosen the small hex nuts, then Unbolt the Axle. If facing the bike, the right side will unscrew off of the Axle . The Left side is welded to the Axle. Make sure you look at it first so you can remember where the spacers go afterward.
