1 - 17 of 17 Posts
My speedo is 10 mph fast on my new used bike so when i was taking off my rear tire I decided to count the teeth on my sprokets. The front one has 15 instead 0f 16, was this done for take off or top speed? Thanks
gives you more top speed...it could be what is causing the speedo to be off but ive only seen it affect the speedo when changing the front sprocket...never went down on my rear sprocket but it is a good possibility...
I went one tooth down on the front and it threw my speed-o off 10 mph. Also you'll see that your shifting alot sooner.
Oh ya better to be faster then your going then slower!
From everything I've read and been told, going down one in the front is roughly equal to going up 2.7 (or about 3) in the rear.
My 96 F3 has also a 15 and Im 45 in the rear. It threw my speedo off by 10-15 but I can figure about how fast I'm going from being used to it. Also, it'll make your bike sound like it's screaming. Mine does. I went back to stock, and the noise quit, then went back to -1/+2 and it's back to screaming like a bitch. gets annyoing on long rides. YEA! for ear plugs
Nope, it actully will give you quicker accel. and a lower top speed...
Depends on the type of bike. Diffrent bikes read the speed from diffrent places so depending on your bike (dont know which one you have) it might read from the front wheel or might read from the gears....
In a vacuum that is allways true, but not here on earth :twofinger
If the bike will not run to redline in top gear stock, its possible that going to a higher gear will increase the top speed. Reason: The RPMs will be higher at the 'old' top speed, and now there is more power to push the bike through the air. Then you have a higher top speed :cool:
Dont forget friction, and aerodynamic drag!
you would seriously need alot more power than you could ever get with a few hundred more RPM to actually make you any faster. At those speeds, the aerodynamic forces are quite high, and even though your bike might now have the right gearing to use the full RPM range, the extra few horsepower you might actually get wouldn't be enough to overcome those forces.
He's -1 tooth on the FRONT, so actually it's quicker accel.
The only thing your missing from that equation is that the motor would have to produce more power... :)
It does produce more power because its at a higher RPM.
Say that the bike "hit a wall" at 140mph. It just couldn't go any further due to drag. Well, you make the gearing shorter, and all of a sudden 140mph happens at a different RPM. A higher RPM.... Higher HP/TQ is available, and it can "push" you better through the drag. Now the top speed is 145 or 150.
(All assuming you weren't at redline when you hit the point where the bike would succumb to the drag)
It still accelerates quicker than stock, and has a higher top speed. It doesn't have a higher theoretical top speed though... When do we ride in theory though? I like riding in real life :twofinger
Physics people! Physics!
1 - 17 of 17 Posts
