1 - 8 of 8 Posts
I have had this problem for as long as i had the bike. left turn signals work just fine but the right ones, both front and back dont work. when i try to turn my right turn signal on, i notice a dim on my gauge display which lets me know that they power is being drawn properly from the switch.... i'm so confused does anyone have any suggestions?
ive checked the bulbs and they look fine, even replaced one of them and no results. maybe my contact points inside my turn signal button are damaged? is there any type of spray or anything i can apply in there to help get a better connection?
Or one of the positive feed wires to the indicators is getting a ground signal from the frame thus causing no worky blinky winky but still dimming your display with the short . I would be sticking my tester leads into the bulb holders and seeing what happens there first .
1 - 8 of 8 Posts
