Neutral Safety Switch Repair Instructions (with pics) - Sportbikes.net
ZZR Mods Talk about, Discuss and Show off your mods to your ZZR Sportbike.
User Tag List
post #1 of 10 (permalink) Old 11-28-2008, 04:13 PM Thread Starter
Finally got that ticket
MJ939's Avatar
Quoted: 0 Post(s)
This thread has instructions on how to replace your neutral safety switch. This is the switch that tells the bike that the transmission is in neutral, allows the bike to start with the clutch engaged and run with the sidestand down, and activates the green light on the dash.
This is not the same as the clutch switch that activates when you pull the clutch in.
Anyway, the repair is extremely easy, but it's always nice to see what you need to do in advance. It takes about 20 minutes.
Here is the new switch which I got on warranty from the dealer. They were happy to just give it to me since they wouldn't have to do the repair.
The switch is installed on the lower left side just behind the fairing.
Take off the left fairing to make it easier to access and remove.
Use pliers to lightly pull off the wire. The metal part loosely grips around the switch part but doesn't require tools to remove.
Here's the switch with the wire pulled off.
continued...
MJ939 is offline
post #2 of 10 (permalink) Old 11-28-2008, 04:13 PM Thread Starter
MJ939's Avatar
Quoted: 0 Post(s)
Use the 14 mm wrench included with the bike's toolkit to remove it.
This was the hardest part of the repair. The switch was really stuck in there and I had trouble turning it. Once it did finally go, it went with a vengeance, and my hand slipped and slammed into the sidestand, cutting it a little bit. Use a socket and ratchet if you have one.
Unscrew and pull out the switch and the washer that's on it. Be ready with a small pan or rag, and be ready to put the new switch on quickly, since a little oil will drip out. I was not really ready for the oil, and I still only got this much spillage:
Don't forget to put the washer on the new switch!
No signs of a problem with the old switch.
Put the wire back on the new switch.
MJ939 is offline
post #3 of 10 (permalink) Old 11-28-2008, 04:14 PM Thread Starter
MJ939's Avatar
Quoted: 0 Post(s)
Prepare a beer for the final check.
1st gear.
Neutral!
MJ939 is offline
post #4 of 10 (permalink) Old 02-16-2009, 08:48 AM
Quoted: 0 Post(s)
Very nice!
Thank you!
I've been having problems with my neutral light being goofy and people have been telling me to check my switch.
Now I know where to look!
mattd313 is offline
post #5 of 10 (permalink) Old 04-01-2009, 08:57 AM
Superbike Champion
BadAssRX-7's Avatar
Quoted: 0 Post(s)
ok i put a jumper on my handle switch so nomatter what was going on it was making contact all the time on all 3 wires. I just put a thing or solder all the way across them. now the "N" is lite up all the time the key is on and it will start with it in gear and with the stand down i can drive off. is this a sign of the 1 u replaced being bad also?
89 Mazda RX-7 Vert Stock. 74 Mazda R.E.P.U. Flare Yellow far from stock. 05 ZZR600, moded well.
BadAssRX-7 is offline
post #6 of 10 (permalink) Old 04-01-2009, 06:11 PM
World 500 GP Racer
rayzzr's Avatar
Quoted: 0 Post(s)
So the neutral light stays on when the switch is on, even if the bike is in gear? I'd fix that, because once the bike is started, how do you know if it is in gear or not? If the indicator is on, and you let out on the clutch, the bike would jump off the sidestand, correct? Maybe I am misunderstanding... Either way I would fix it. It sounds like you bypassed it, which may not be a good thing if I am understanding what you are saying...
Where me and the bike have been
ZZR 600: Dynojet stage 1, FP +4 advancer, Yoshimura RS3 slip on, K&N filter, Euro ECU, 42T Driven rear
ZRX 1200: K&N filter, Ivan's Jet Kit, +4 Kwick advancer, 45T SuperSprox rear, SS/CF Fully Muzzy Exhaust, Muzzy block off plates
rayzzr is offline
post #7 of 10 (permalink) Old 05-18-2009, 09:18 PM Thread Starter
MJ939's Avatar
Quoted: 0 Post(s)
I think what Ray is saying is right. You seem to have bypassed or shorted across that part of the circuit, creating a false closed-circuit even when the switch is open. I'm not sure if the switch can fail-closed, but mine didn't. When mine failed, it was open-circuit all the time.
Your situation does sound dangerous, since the bike will allow you to ride with the sidestand down, which could be very bad.
Originally Posted by mattd313 View Post
Very nice!
Thank you!
Thanks, glad it helped!
MJ939 is offline
post #8 of 10 (permalink) Old 07-28-2009, 08:37 PM
Quoted: 0 Post(s)
thanks for the help mj939! you've been a great help!
tonyp216 is offline
post #9 of 10 (permalink) Old 04-08-2011, 10:42 PM
djdcm0722's Avatar
Quoted: 0 Post(s)
do you by any chance happen to have a part number? I can't seem to find one. I have an '08
djdcm0722 is offline
post #10 of 10 (permalink) Old 06-21-2011, 12:02 AM
riverszzr's Avatar
Quoted: 18 Post(s)
Garage
13151-1085
switch-comp
$11.95
Who needs banning today?
riverszzr is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Neutral Safety Switch? wrillo ZZR-600 6 09-22-2008 09:26 AM
Where is my neutral safety switch on my 99 F4? sorny CBR600F Series 0 03-20-2008 07:40 PM
Clutch Safety Switch Question frankstermt_zzr ZZR-600 9 04-26-2007 11:52 AM
HJC CL-14 Switch helmet (pics) jjduke15F4i Riders Gear 10 09-07-2004 11:08 PM
Superhawk neutral switch wiring question Wolf Help Me Fix It 1 07-22-2004 04:04 PM
You may post new threads
You may post replies
Refbacks are Off
