Sportbikes.net
Sportbikes.net (https://www.sportbikes.net/forums/)
-   ZZR-600 (https://www.sportbikes.net/forums/zzr-600/)
-   -   Need Help Fast! Headlights not working! (https://www.sportbikes.net/forums/zzr-600/387131-need-help-fast-headlights-not-working.html)
unforgiven 04-11-2008 06:50 PM
I HAVE SOLVED MY PROBLEM, BUT READ IF YOU WANT A LAUGH
I have my 2008 ZZR tore down putting on some Gregg's flushmounts. I pulled the nose off, unplugged the harness and wired up the flush mounts. I plugged the harness back in to test it before putting it back together and my headlights do not work now. I even rewired the stock blinkers to see if the Greggs were causing problems. Here is what is going on:
Third light in front works
Turn signals work front and back
Brake light works
Tail light works
It appears all the other lights are working but no headlights on low or high.
I pull the seat and the checked the fuses in the box and all are ok. I saw in the manual where the headlight also has a fuse off to the side and it is fine also.
I'm stumped at this point and don't know what else to do. The headlight bulbs look ok and the greggs running light when wired in (unhooked them in case they were a problem) do not work either. I assume they run off the headlight and the circuit is dead but I'm not sure.
I could test the connector but I don't which ones go to the light or how to test them.
Anyone have any ideas what is going on?
Thanks.
unforgiven 04-11-2008 06:57 PM
Ok. I get the dumbass of the year award, but I'll share in case it happens to anyone else. It appears that the lights don't come on until you crank the bike. I never noticed from the pilot seat. I crank it and the light came on fine.
ZZRrocket 04-11-2008 07:03 PM
Yep that would be a true statement. When you turn the key the center running light comes on. But the headlight doesn't come on until you crank the starter.
+1 on the Dumbass of the year award:lao
zzr6oo187 04-11-2008 07:44 PM
but just in case it happens because of a different prob there is 2 fuses for the lights one in the junction box and 1 in between the frame and tail on the right side if you're standing behind the bike
unforgiven 04-11-2008 09:18 PM
Yep! Found and checked both of those and they were obviously fine. I'm used to my 1000RR that comes on when the key is on. Never thought about lights not coming until you crank it. :bitchslap
rayzzr 04-12-2008 01:00 AM
FYI - if you blow the fuse in the taillight circuit the gauges will not light up. I shorted one wire to ground on accident installing an LED license plate and popped a fuse. I also noticed the gauge lights were not on. That would be obvious at night, but next to impossible to tell in the daytime.
peoples1234 04-12-2008 04:30 PM
It happens to the best of us! At least everything checked out okay and you got your wife back on the road :dblthumb
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
