Sportbikes.net
Sportbikes.net (https://www.sportbikes.net/forums/)
-   ZZR-600 (https://www.sportbikes.net/forums/zzr-600/)
-   -   Valve adjustment question? (https://www.sportbikes.net/forums/zzr-600/365026-valve-adjustment-question.html)
teamspeednautik 08-15-2007 05:20 PM
Hey guys,
I had a question on valve adjustment on the zzr's. Ive got 8600 miles on my 05 ZZR. I Bought it at 8000 miles on the odo for 4900. But the thing is there werent any maintanence records for the bike that he kept and he was the second owner. Should i go and get the valve adjustment done just to be safe? I changed all the fluids about 2 days after purchasing the bike. It just sparked my attention about doing a valve adjustment at 7k miles as routine maint. Bike runs and pulls strong. No weird noises, leaks, etc. Those of you that have reached the 7k mark, have you done them yet?
Any input will be appreciated! :headbang
OreoGaborio 08-15-2007 05:30 PM
heh, i'm at 26k miles & haven't adjusted em yet.... i should probably get on that, huh :D
I wouldn't worry about it much. Check the clearances if you want but they'll probably be w/in spec still.
teamspeednautik 08-15-2007 05:38 PM
26k miles! Daaaymn. Haha. :lol My 8600k miles seemes minute to that number! I was just wondering because i read that at 7k is the next big maint. service which is the valve adjustment. But i mean, the bike runs strong, and sounds the same as well! Cool though, Thanks Oreo!
Ps. Thats a nice go-ped? in the avatar! :onfloor
Thanks again.
mandrex 08-15-2007 05:47 PM
Just because his bike is apperently fine at 26k (and there is no real way to know if they are in spec without looking) does not mean yours is as well - it does not hurt to check. Adjusting them to spec will only make the bike run better. It's not hard to check them yourself either. Worst thing you'll find out if it does not need it is that it's all good and learn a bit about your top end in the process. If they need to be adjusted that's not brain surgery either.
teamspeednautik 08-15-2007 05:50 PM
How can i see if they are adjusted to spec? If you can lead me in the right direction mandrex that'll help greatly! Thanks!
mandrex 08-15-2007 05:55 PM
Download the service manual (sticky thread here) and you will see how to get to the valves and what the spec is. You can get shims at your local auto parts store (for next to nothing) and have at it. Just open her up and use the shims to check - nothing that requires a PhD. There are probably a million write ups on the web about how to do a "valve job" that would do a better job of explaining the process at length than I could here.
Best to have a torque wrench as well if you do need to adjust.
teamspeednautik 08-15-2007 06:10 PM
OHhhh. Alright Thanks For The Lead! :cheers
OreoGaborio 08-15-2007 06:38 PM
it's involved enough that I'm enlisting the help of a couple of my mechanic friends. Unless you're used to opening up engines & playing with valve trains, I wouldn't do this alone even w/ the service manual.
teamspeednautik 08-15-2007 10:21 PM
Oh shit. I wish you lived closer! Id wish to be on that list of help! Ahh Damn. Yeah im not really used to opening up engines and playing with valves...... Ill just wait about two-three weeks before i take it in then! I dont want to fuck anything up :bitchslap !
lecchilo 08-15-2007 11:24 PM
You won't get used to it unless you try... I've found out from working on my ex-car that it's all just nuts and bolts... you just have to be more careful with some of them, and not drop stuff where it's not supposed to go haha
I'm going to open it up after a few thousand miles and see how it looks underneath... might be easier than you think, many things are when talking about bike/car maintenance
OreoGaborio 08-15-2007 11:56 PM
checking clearances is easy enough... it's adjusting the valves that's a pain in the ass. I've got an engine builder lined up that'll do it for 150 for me.
mandrex 08-16-2007 12:10 AM
You should be comfortable with and at least reasonably prepared to tackle a project - be it a simple oil change or an engine rebuild... Where that level of comfort is depends on you, your skills and your "talent" for mechanics and your experience. People here pay a couple hundred bucks for the first “service” for something they can do in 20 minutes for $40 with basic hand tools almost anyone owns but if that works for them so be it.
I look at it this way, I've been in the service area on most local dealerships (bike and car) and if I trust the chimps that typically occupy such spaces with my cars and my bikes I might as well trust myself.
I may have been a bit blasé in saying that you should tackle this yourself. I don’t know your mechanical skill level or experience. Only you can figure out if it’s something you want to do or pay a “pro” for.
OreoGaborio 08-16-2007 12:30 AM
I know you're not speaking directly to me, but I fully understand your reasoning... and 99.9% of the time I'd agree with you & I'd do it myself as I do alot of my own work on my street bike, race bike & dirt bike... but this time, my "pro" really is a pro... he used to work for Kawasaki's AMA team back in the day :D
teamspeednautik 08-16-2007 01:09 AM
You should be comfortable with and at least reasonably prepared to tackle a project - be it a simple oil change or an engine rebuild... Where that level of comfort is depends on you, your skills and your "talent" for mechanics and your experience. People here pay a couple hundred bucks for the first ďserviceĒ for something they can do in 20 minutes for $40 with basic hand tools almost anyone owns but if that works for them so be it.
I may have been a bit blasť in saying that you should tackle this yourself. I donít know your mechanical skill level or experience. Only you can figure out if itís something you want to do or pay a ďproĒ for.
Mandrex, you do make a good point. Well ive worked on my bmw that i had, and now have a project 86 toyota pickup to haul my bike around and just did a carb. rebuild on it. But first off, i think ill check the clearances first. And if there fine, i'll just leave it alone til the time comes. As far as maint. is concerned, ive always done it on my cars. But a bike, since im new to it, seems somewhat intimidating. But I'll slowly get into it. Thanks guys. :)
lecchilo 08-16-2007 01:53 AM
One thing I thought of when I read someone post "clearances will probably be within spec" is that why not make them even more within spec while you're already in there... I have no idea what's going on with the valves yet, but by the time 7000 miles comes up, I will hopefully learn and do it myself... what I'm trying to say is if you have the whole engine apart, you might as well move the valve that .03mm
ot... what kind of BMW did you have?
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
