Valve adjustment and some other questions - Sportbikes.net
User Tag List
post #1 of 7 (permalink) Old 05-31-2007, 10:46 PM Thread Starter
Quoted: 0 Post(s)
So I've had my 05 ZZR600 for almost 2 months now and in that time its went from 3900 miles to a little over 7200 right now. Now if I remember correctly we are supposed to get a valve adjustment at 7500 miles. How much does this usually run? Does it REALLY need to be done? Will I notice a difference in power or anything?
Also, I usually have to crank my bike for about 4 or 5 seconds to get it to start, or just give it a tiny bit of gas and it fires right up. Will this service help or is something else wrong? Maybe Im just a bit jealous of the FI bikes and im thinking to much about it.
Last question. A friend of mine just bought an 07 ZZR and I noticed his throttle was smooth, it felt like the FI bikes I've rode. I guess mine feels "stiffer", can this be fixed with a new throttle cable, grips, grease, anything?
Thanks guys.
tford06 is offline
post #2 of 7 (permalink) Old 05-31-2007, 11:25 PM
Grimy's Avatar
Quoted: 0 Post(s)
It is a carb engine so giving a lil gas is normal OR just open choke up the throttle can be adjusted im pretty sure bc my mechanic did something with mine and it felt much better...
1st Mar Div
USMC irrrrr
Bike - 2006 Kawasaki ZZR600 - SilverGoodies - Yoshimura RS-3 Stainless Steel Oval Bolt-On with Race Baffles exhaust, Goodridge Stainless Steel Front Brake Lines, Factory Pro Ignition Advancer 4 degrees, KN&N Performance Air filter, R&G Frame Sliders, R&G Racing Slider Bar Ends, Zero Gravity Dark Smoke Double Bubble Windscreen, MOTOTECK undertail with intergrated LED amber turn signals, MOTOTECK Flushed front LED turn signals, LED Brake Lights,
Grimy is offline
post #3 of 7 (permalink) Old 06-02-2007, 05:51 PM
CandyFireZZRed's Avatar
Quoted: 0 Post(s)
IDK bout the valve adjustment...I would have it done...but as for the 4-5 second crank w/o any throttle or choke, that's normal. It's a carb'd bike, not fuel injected so it takes a lil fuel to fire it up. Just give a little flick of the throttle when starting and it will fire right up every time pretty much instantly. And if it's the first start up of the day or for several hours, open the choke up
CandyFireZZRed is offline
post #4 of 7 (permalink) Old 06-04-2007, 08:01 AM
djones31's Avatar
Quoted: 0 Post(s)
I asked the dealership where I bought my bike about valve adjustment and they said at 7500 miles they check the valves and adjust if nessesary. They said that most street riden bikes(if riden like your supposed to ride a STREET bike) do not need adjusted, but if riden hard would need some kind of adjustment, Since you bought yours used deffinetly have them checked and adjusted if nessesary. Proper valve adjustment would make a big diff in a bike that needs it. As for price call your dealer to find out what they charge.
djones31 is offline
post #5 of 7 (permalink) Old 06-04-2007, 11:08 AM
Cheap Bastid
OreoGaborio's Avatar
Quoted: 0 Post(s)
my bike has 23k miles on it... valves haven't been touched. I'm sure they're a little tight, but my point is, i seriously doubt your valves will need much adjusting. But, like djones said, you should at least check the clearances to make sure.
Personally, I wouldn't trust a dealer I didn't know w/ this check... they can very easily say "oh yeah, they're outta spec" and not do a thing to change em. Either find a friend who's mechanically savvy or pick up a shop manual & do it yourself. It's not too tough of a process, just gotta do your research, follow directions & have the right tools.
-Pete
LRRS/CCS #82
(RiderCoach),
(Assistant Chief Instructor)
| Pine Motorparts/PBE Specialists |
OreoGaborio is offline
post #6 of 7 (permalink) Old 06-04-2007, 02:03 PM
Thread killer
Quoted: 0 Post(s)
its not that hard to do. the hardest part for me was measuring the clearances. it's a pain in the ass to get feeler gages down in there.
JINXR is offline
post #7 of 7 (permalink) Old 08-13-2008, 10:32 PM
Tommy69's Avatar
Quoted: 0 Post(s)
so has anyone actually done an adjustment themselves, where did you find a decent shim kit for this?
Tommy69 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
You may post new threads
You may post replies
Refbacks are Off
