FI Codes - Sportbikes.net
User Tag List
post #1 of 1 (permalink) Old 11-17-2006, 07:22 PM Thread Starter
Anything
jk750's Avatar
Quoted: 0 Post(s)
FI Codes
GSXR Fuel Injection Code List -
To read your code you will need to go into Dealer Mode. Don't panic, it's easy. The dealership has a 'special tool' for this but you can easily make your own.
Take off the front seat. Behind the battery you will find a white open ended 6 pin connector (might be 10 pin for k6?).
If it has a cap take it off and as you are looking at it jump the right wires top and bottom with a paper clip.
Turn the key to the ON position and you will see on your dash a C code where the temp would be.
(or C00 if you have no codes. This is often the case when the SET valve is the problem as the computer resets it if you turn your bike off, otherwise it would be C46)
It should be a 'C' with a number, like one of these >>>
C14 - THROTTLE POSITION SENSOR
C15 - ENGINE COOLANT TEMPERATURE SENSOR
C21 - INTAKE AIR TEMPERATURE SENSOR
C22 - ATMOSPHERIC PRESSURE SENSOR
C23 - TIPOVER SENSOR
C24 - IGNITION SIGNAL #1
C25 - IGNITION SIGNAL #2
C26 - IGNITION SIGNAL #3
C27 - IGNITION SIGNAL #4
C28 - SECONDARY THROTTLE VALVE ACTUATOR
C29 - SECONDARY THROTTLE POSITION SENSOR
C30 - SECONDARY THROTTLE CONTROL UNIT
C31 - GEAR POSITION SENSOR
C32 - INJECTOR SIGNAL #1
C33 - INJECTOR SIGNAL #2
C34 - INJECTOR SIGNAL #3
C35 - INJECTOR SIGNAL #4
C41 - FUEL PUMP CONTROL SYSTEM
C42 - IGNITION SWITCH SIGNAL
C46 - EXHAUST CONTROL VALVE ACTUATOR
jk750 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
WON'T START - Laundry List of Diag/Fault Codes DefyInertia FZ6/FZ6R 7 07-14-2006 09:38 AM
04 R1 not starting. er-1 & er-2 trouble codes xxxxGold 1 YZF-R1 5 05-07-2006 11:38 AM
04 R1 not starting. er-1 & er-2 trouble codes xxxxGold 1 Help Me Fix It 2 04-24-2006 05:57 AM
Color codes Karoshi FZ6/FZ6R 4 07-08-2004 09:40 AM
You may post new threads
You may post replies
Refbacks are Off
