pretty stupid question.. - Sportbikes.net
Riders Gear Helmets, gloves, jackets, boots, etc. You need to protect yourself from everything and anything. So what should you buy? Check out what others have to say.
User Tag List
post #1 of 4 (permalink) Old 03-17-2008, 10:53 PM Thread Starter
ninjaridr64's Avatar
Quoted: 0 Post(s)
do you have to do anything special to wash textile jackets? yah i know stupid but i dont wanna mess it up lol
ninjaridr64 is offline
post #2 of 4 (permalink) Old 03-17-2008, 10:56 PM
World Superbike Champion
kxl77's Avatar
Quoted: 0 Post(s)
Check the directions on your jacket; each jacket should have different requirements. Low heat only, dry clean, etc.
kxl77 is offline
post #3 of 4 (permalink) Old 03-17-2008, 11:02 PM
Superbike Champion
Blake331's Avatar
Quoted: 0 Post(s)
Not a dumb question........here's what I found at Tourmaster's website
Caring for your Tour Master and Cortech Gear
Textile Garments:
Tour Master and Cortech garments utilize several fabric technologies to provide the rider with the best possible experience when riding. These technologies are designed to improve abrasion resistance, ventilation or water- and wind-proofing of the garment.
In caring for your garment please:
* Remove all body armor from the garment
* Wash in cold water or low temperature setting using mild soap. Avoid using any harsh detergents.
* Airdry only, after all soap is removed from the garment.
* Do not dry in the sun as heat may become excessive and break down waterproof membranes.
PLEASE DO NOT:
* Use excessive heat
* Use bleach or petroleum based cleaners
* Dry clean or Iron
Textile Luggage Care :
Road grime and soil may be removed with fabric spray cleaner or mild laundry detergent and lukewarm water.
Handling Oil or Grease Stains:
Oil or grease stains should be initially treated with a dry cleaning solvent immediately followed by fabric spray cleaner or mild laundry detergent and lukewarm water
It is recommended that you pretest all cleaning products in a hidden area to ensure compatibility with the garment.
Leather Garments
Cleaning
Use commercially available leather cleaners and conditioners for all water-based spills and stains.
For oil-based stains, wipe the stained area clean with a clean dry cloth and allow the remainder of the stain to dissipate into the leather over 24 hours.
Do not use leather cleaners or conditioners, water or soap on oil-based stains. If stain is still visible, seek out a professional leather cleaning specialist in your area for professional cleaning.
Some of the leather used in our garments is 100% washable leather. Please refer to the product tag contained within the garment for further instructions and to confirm its washability.
General Leather Care
Do not store your leather garment in plastic or non-breathable sealed bags as it can promote mildew.
Avoid storing in direct sunlight or in excessively dry conditions as this will accelerate leather aging and cracking
When wet, allow leather garments to airdry naturally away from any heat source to maintain shape and sizing.
Avoid extreme heat or humidity that may damage leather‚€™s natural oils.
Leather can be treated with a leather conditioner yearly to restore flexibility and proper moisture levels.
In winter, promptly remove salt deposits from garments by sponging with clear water, then follow with the above treatment for wet or damp leather. Allow to airdry.
Avoid wearing in very humid and dry environments. This will shorten the life expectancy of a leather garment.
Do not use waxes, silicone products or other leather preparations that impair a garment's ability to breathe.
Wrinkled leather garments should hang out while on hanger. Storing with creases and folds will stress the leather and cause wrinkles in the garment.
Seek out a professional leather care specialist when your garment becomes excessively worn or soiled for professional care.
Boot and Glove Care
Boots
If boots become wet, dry them out in a well-ventilated, dry place away from heat sources and direct sunlight.
When storing boots, keep in a well-ventilated dry area that will promote the leather to stay supple avoid mold and mildew.
If applicable, remove inserts, insoles or booties and store them separately from the interior of your boots.
For prolonged storage in excess of 2-3 months, stuff boots with newspaper to help them keep their shape.
To clean your boots, clean with a sponge or soft cloth and water to remove any mud or soil. Dry with a soft cloth. Check any articulated plastic parts for squeaks and lubricate with silicone lubricant as necessary.
Check your boots carefully after each use.
Do not use harsh cleansers or alcohol- or solvent-based products as these will harm any personal protective equipment guarding ankles or heels.
Glove Care
If gloves become wet, dry them out in a well-ventilated, dry place away from heat sources and direct sunlight.
When storing gloves, keep in a well-ventilated dry area that will promote the leather to stay supple avoid mold and mildew.
To clean your gloves, clean with a sponge or soft cloth and water to remove any mud or soil. Dry with a soft cloth.
Synergy Electrically Heated Apparel Liners & Gloves
Tour Master Synergy electrically heated apparel liners (excluding gloves and temperature controllers) are machine washable. Please follow the step-by-step instructions listed below to clean and care for your Synergy Apparel Liner:
1. Disconnect the garment from its Synergy power lead and remove the temperature controller.
2. Machine-wash on the gentle or delicates cycle using the cold water setting on your clothes washer and use a mild detergent. Do not use bleach or cleaning solvents as they will damage the garment.
3. Remove your Synergy liner from the washer and hang up to air-dry completely. Do not use a clothes dryer.
NOTICE: DO NOT SOAK SYNERGY APPAREL LINERS FOR EXTENDED PERIODS, AGGRESSIVELY WRING OUT OR TWIST THE LINER TO DRY IT, AS THIS WILL DAMAGE THE HEATING ELEMENTS AND LIMIT THE LIN
Blake331 is offline
post #4 of 4 (permalink) Old 03-17-2008, 11:03 PM Thread Starter
Quoted: 0 Post(s)
yeah i would have checked the tag... if i still had it and thanks for the long write up it helps ill go by that and hope for the best
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
Scared a cager pretty good today pitts FZ6/FZ6R 21 07-08-2007 02:07 PM
Possibly dumb tail light question... CCHOUSEKY FZ6/FZ6R 5 03-22-2007 10:11 AM
Newb Question FZ6 B-Rad FZ6/FZ6R 10 03-14-2007 10:38 PM
Stupid question jeostang General Sportbikes 19 10-13-2004 09:29 PM
Question about the Ninja 500 Mr_anderson New Riders 25 07-14-2004 03:17 PM
You may post new threads
You may post replies
Refbacks are Off
