bike won't go into 1st gear - Sportbikes.net
User Tag List
post #1 of 11 (permalink) Old 08-08-2007, 08:16 PM Thread Starter
Quoted: 0 Post(s)
hey guys. i have a little problem with my 01 gsxr 600. sometimes when i'm stopped at a light, the bike won't go into 1st gear after stopping. i keep pushing it down but it won't budge. it doesn't always happen but whenever it happens, it makes me panic. the bike was dropped once and caused the left footpeg by the gear shifter to bend and twist a little bit. could the problem be caused by the fall? i dunno what to do.
hoho is offline
post #2 of 11 (permalink) Old 08-08-2007, 09:23 PM
~ Master Technician ~
2001FZ1's Avatar
Quoted: 0 Post(s)
Your linkage might be binding up and preventing it from moving correctly. Each time you push down, it should go to the next lower gear and then the lever should return to the middle position. Is the shift lever returning?
Need a better riding position? Check out
. They are great!
Past bikes: '82 Yamaha Maxim 750, '89 Kaw. ZX7, '94 Kaw. ZX9R, '01 Yamaha FZ1, 04 Kaw. EX-250 ~ over 18 years & 120,000miles of riding experience.
2001FZ1 is offline
post #3 of 11 (permalink) Old 08-09-2007, 03:51 PM
World 500 GP Racer
Redstar11's Avatar
Quoted: 0 Post(s)
If the linkage was bad, he would have problems downshifting into any gear. Examine your linkage anyway.
Also, try slipping the clutch a little bit to move the countershaft and see if that helps you put it into gear.
Pain, necessary to know.
Redstar11 is offline
post #4 of 11 (permalink) Old 08-13-2007, 07:04 AM Thread Starter
Quoted: 0 Post(s)
the shift lever does return but it just won't go into first gear sometimes. had the problem again yesterday at a light when i tried to put it into first gear from 2nd so i had to start off in 2nd gear. what is the linkage? i am a noob.
hoho is offline
post #5 of 11 (permalink) Old 08-13-2007, 09:01 AM
Sidehacker Extraordinaire
jeepcoma's Avatar
Quoted: 0 Post(s)
It's a normal problem caused by coasting to the light with the clutch in and shifting down through several gears. It's because of the design of motorcycle transmissions. You should go downshift-release clutch-downshift-release clutch-downshift release clutch until you get to first gear, while still rolling, and the clutch released. Hold the clutch in only when you're coming to a stop or are sitting at the light.
2004 Yamaha FZ6 "Dagmar Aaen"
19?? Dnepr MT-11
jeepcoma is offline
post #6 of 11 (permalink) Old 08-13-2007, 10:29 AM
World 500 GP Racer
Redstar11's Avatar
Quoted: 0 Post(s)
It's very possible to line up the gears on the countershaft in a manner that the dogs on the sliding gears can't engage each other. You need to roll the bike forwards or backwards to spin the countershaft.
post #7 of 11 (permalink) Old 08-13-2007, 07:26 PM Thread Starter
Quoted: 0 Post(s)
oh...i do sometimes keep rolling with the clutch in...i guess that's causing that problem......thanx a lot guys
hoho is offline
post #8 of 11 (permalink) Old 08-13-2007, 07:55 PM
Making Horizons Vertical
dubbs693's Avatar
Quoted: 2 Post(s)
Garage
Ya.. Since I started doing that, I never had an issue clicking into first..
Let us know how it works out for you..
Weekend Car - 2003 Honda S2000 - Black
Daily Driver - 2013 Cadillac ATS 2.0 Turbo - Black
Sportbike/Cruiser/Enduro - 2013 Ducati Multistrada - Red
Beater - 2011 Toyota Prius - Black
dubbs693 is offline
post #9 of 11 (permalink) Old 08-13-2007, 09:59 PM
Quoted: 0 Post(s)
My bike does this too, its most definatly a noob thing from not hitting every gear when downshifting. I found theres two ways to fix it if it wont downshift.
Let out the clutch in. gear and let the bike stall, start it then downshift (this option should be avoided)
you can roll the bike back and forth in neutral like someone stated. Or I like to release the clutch then grab it all the way again and then it will usually shift to first.
haha thats three ways
TemplarForGod is offline
post #10 of 11 (permalink) Old 08-14-2007, 07:34 PM Thread Starter
Quoted: 0 Post(s)
i'll try that rolling back and forth one if it happens again. sometimes it gets stuck in 2nd gear and i usually just start out in 2nd just cuz i don't wanna let the clutch out and stall the engine.
hoho is offline
post #11 of 11 (permalink) Old 08-14-2007, 08:01 PM
Quoted: 0 Post(s)
Just learn to downshift correctly...practice at every intersection / stoplight where you have plenty of time to stop. I'd forgotten how many things I knew about riding, until I started riding again...I rarely have to use much brake at all when I've got fair warning at a stop light... I simply go down through the gears, and right before I stop, I've got the clutch disengaged, with the bike in first.....
Chris
I thought I Was wrong once...but I was mistaken
ctandc is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
Whats the best r6 bike for a beginner? hellspawn General Sportbikes 73 07-10-2008 01:31 AM
Why "squid"? david223 General Sportbikes 26 11-02-2007 05:40 AM
Just finished my first night of riding at MSF mitsuclipse General Sportbikes 35 07-28-2007 08:21 PM
What's a good 500 bike? protective gear? MrGTO New Riders 5 01-31-2007 11:33 AM
new to the forum and riding need some tips Justizzle New Riders 47 09-06-2004 04:31 AM
You may post new threads
You may post replies
Refbacks are Off
