FI warning light is blinking and bike is dead - Sportbikes.net
User Tag List
post #1 of 12 (permalink) Old 08-01-2007, 06:14 PM Thread Starter
OEM
Umbrella Girl
OEM's Avatar
Quoted: 0 Post(s)
2003 GSX-R 750
All of a sudden, the FI warning lights starts blinking and my bike shuts down - usually at startup in the morning or when re-starting after a stop. It used to start up after turning off ignition, and on ignition, and the start button, but today, my bike is dead. It starts and stays on for 2 seconds and shuts down with red FI light blinking and the code is "FI".
Before taking to dealer or repair shop, and spending loads - can anyone tell me what the code means?
Thanks in advance
:alky
2003 GSX-R 750
OEM is offline
post #2 of 12 (permalink) Old 08-01-2007, 06:59 PM
Quoted: 0 Post(s)
you have a fuel injection issue
blinkEzx7r is offline
post #3 of 12 (permalink) Old 08-01-2007, 07:00 PM
Quoted: 0 Post(s)
ask JK750 he'll know what's up
post #4 of 12 (permalink) Old 08-01-2007, 07:20 PM
Is it spring time yet?
down_on_monday's Avatar
Quoted: 0 Post(s)
You can check the code by putting into dealer mode...The plug you are looking for is under the seat and has a rubber cap over it. Use a small paper clip and insert it just as the picture shows. Where the F1 was there will be a 'C' code...could be a number of things. I'll post the 'C' code list in a second for ya.
down_on_monday is offline
post #5 of 12 (permalink) Old 08-01-2007, 07:27 PM
Quoted: 0 Post(s)
Here's the list of FI codes...
GSXR Fuel Injection (FI) Code List:
C14 - THROTTLE POSITION SENSOR
C15 - ENGINE COOLANT TEMPERATURE SENSOR
C21 - INTAKE AIR TEMPERATURE SENSOR
C22 - ATMOSPHERIC PRESSURE SENSOR
C23 - TIPOVER SENSOR
C24 - IGNITION SIGNAL #1
C25 - IGNITION SIGNAL #2
C26 - IGNITION SIGNAL #3
C27 - IGNITION SIGNAL #4
C28 - SECONDARY THROTTLE VALVE ACTUATOR
C29 - SECONDARY THROTTLE POSITION SENSOR
C30 - SECONDARY THROTTLE CONTROL UNIT
C31 - GEAR POSITION SENSOR
C32 - INJECTOR SIGNAL #1
C33 - INJECTOR SIGNAL #2
C34 - INJECTOR SIGNAL #3
C35 - INJECTOR SIGNAL #4
C41 - FUEL PUMP CONTROL SYSTEM
C42 - IGNITION SWITCH SIGNAL
C46 - EXHAUST CONTROL VALVE ACTUATOR (1000 ONLY)
post #6 of 12 (permalink) Old 08-04-2007, 04:05 AM
SLEEPY6's Avatar
Quoted: 0 Post(s)
Question
I Have A Friend With The Same Problem But Its An 2000' Gsxr 750 Would These Codes Be The Same For That Year As An 03' ?
SLEEPY6 is offline
post #7 of 12 (permalink) Old 08-06-2007, 06:54 PM Thread Starter
OEM
Umbrella Girl
OEM's Avatar
Quoted: 0 Post(s)
Thank you, will check it out next time it dies. When I went to test it, it started right up, so it appears the problem is reproducible regularly when its HOT.
:alky
2003 GSX-R 750
OEM is offline
post #8 of 12 (permalink) Old 08-27-2007, 04:27 PM Thread Starter
OEM
Umbrella Girl
OEM's Avatar
Quoted: 0 Post(s)
I found code, please assist further
Ok, so the bike finally died again, this time I had a paper click ready to go and I had the read cover open and ready to go.
Code is C23, which is the TIPOVER SENSOR. Do I just need to clean out the contacts or something or is it more serious?
:alky
2003 GSX-R 750
OEM is offline
post #9 of 12 (permalink) Old 08-27-2007, 06:49 PM
RayOSV's Avatar
Quoted: 1 Post(s)
Assuming the bike wasn't on its side, yes check the connections to the sensor. The sensor itself could also be bad.
RayOSV is offline
post #10 of 12 (permalink) Old 08-27-2007, 10:43 PM
World 500 GP Racer
Redstar11's Avatar
Quoted: 0 Post(s)
Suzuki usually mounts their tip over sensors near the battery on the GSXR's. Find it, and make sure it is securely fastened the way it is supposed to be. Usually it will say "UP" or something on the unit, as it needs to be positioned correctly.
[COLOR=SlateGray]This thought is all I have to trust upon, when light is gone.[/COLOR]
[COLOR=Red]The words between the lines, The worst of the best, The dust on the pews, Nihil![/COLOR]
[COLOR=DarkRed]Leave dependence to drones. Lies to the harvest for the truth to be sown.[/COLOR]
[COLOR=DarkSlateGray]Pain, necessary to know.[/COLOR]
Redstar11 is offline
post #11 of 12 (permalink) Old 09-10-2007, 11:40 AM Thread Starter
OEM
Umbrella Girl
OEM's Avatar
Quoted: 0 Post(s)
Last request for help before taking to the dealer$hip
After reading several posts online, I took the tip over sensor, and zip-tied each end of the bar inside so the metal ring never touches the metal part. In other words, I disabled the tip-over. Problem is still there though (bike dies).
Seems to be when I am moving only, never dies when idling. Seems to be when I am accelerating from a slow speed, after slowing down, like for a corner. Always seems to be when the bike is warm (display shows about 170 to 180 degrees). When it dies, the error code is always C23, but tip-over is disabled. Could it be a false code? Any other ideas?
:alky
2003 GSX-R 750
OEM is offline
post #12 of 12 (permalink) Old 09-10-2007, 12:18 PM
Zumina's Avatar
Quoted: 0 Post(s)
I would recheck the "system" you've made for the tip over sensor or just replace the thing all together. The sensor is still active if it's killing the bike when it's assuming an angle greater or less the 0 degrees.
Zumina is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
my first liter bike and im pissed off!! alex70 General Sportbikes 44 04-07-2007 03:55 PM
06 Gsxr1000 Fi Light Blinking GIXXKID Help Me Fix It 2 04-01-2007 09:29 PM
Finally Bought My New Bike PaulR General Sportbikes 8 03-28-2007 10:56 AM
Tail light Intagrator kit mitchellgt Help Me Fix It 1 08-14-2004 04:54 PM
You may post new threads
You may post replies
Refbacks are Off
