Hep with Ninja fuel line routing - Sportbikes.net
User Tag List
post #1 of 4 (permalink) Old 03-23-2007, 01:28 PM Thread Starter
Quoted: 0 Post(s)
Hello all,
I am in the process of working through a 1986 Ninja ZX6R that has been out of service for about 3 years. The previous owner routed a fuel line from the petcock to an on off fuel valve for what I am assuming was a leaky petcock. The problem that I am having is determining which line goes where. I have all the vacuum lines in place but I do not know where the fuel line should be routed. I have attached photos in hopes that someone will have this info. The petcock has 2 ports, the tank has a port that is on the bottom and has an electrical pigtail for the fuel gauge. I have also located a port on the top of the tank that sits below the left side of the seat and another below the airbox. Any help with this would be appreciated! Noel
ID:	117505   Click image for larger version
labadida is offline
post #2 of 4 (permalink) Old 03-23-2007, 04:35 PM
second chimp in space
enos's Avatar
Quoted: 0 Post(s)
The one by the seat is a drain. If this is anything like the '87 750 I had then if you look inside you'll see this tube going up through the tank up to the cap, where there is a hole for gas to go down if you happen to overfill. Usually there's a hose here that goes down to around the pegs somewhere along with a few other drains.
On the petcock, the big one is fuel (bottom on your pic i think), and the small one is vacuum (left on the pic). The vacuum connects to a nipple on the front top of one of the carbs (probably #2). If all your carbs have a nipple (like the 750 did) then take your pick. The vacuum from the engine opens the petcock (there's a diaphragm in there, could be broken or dirty if the petcock's leaking) and closes again when you kill the motor. You can buy rebuild kits for $25 or so, or if you're gonna use the separate fuel valve you don't really need this hose at all and just put the petcock on prime. I'd personally fix the petcock. And make sure that none of the nipples on the carbs are left open or else that cylinder will run lean.
The electrical is for the fuel gauge like you know, and I'm not sure on the port on that, but it's probably a drain/vent. Give it the same treatment as the other drain.
As for routing the hoses, make sure there are no kinks, that all curves are nice and round, and that they stay like that when the tank is down. Shorten hoses if necessary.
enos is offline
post #3 of 4 (permalink) Old 03-23-2007, 06:12 PM
emw
Ride Twins!
emw's Avatar
Quoted: 0 Post(s)
I got a pic on my old '85 Ninja 600
The orange line is the fuel line, connect that to the bigger hole of the petcock as enos said.
As for the vacuum lines, there should be a hose connecting the vacuum nipples on carbs #2 and #3 - they come together in a "T" connector (hidden in this picture by a huge hose) and from there, get connected to the smaller hole of the petcock.
The nipples on carb #1 and #4 are connected at the "T" (visible in this picture) and from there is connected to a black box, very near where the gas tank mounts onto the rubber donuts.
Also, I suggest adding a fuel filter while you're at it.
[QUOTE=ReadNotReed2007;4152205]
You sound like you lead a boring life my friend.
A very boring, un-baller life.[/QUOTE]
emw is offline
post #4 of 4 (permalink) Old 03-23-2007, 10:30 PM Thread Starter
Quoted: 0 Post(s)
Awesome, thanks so much for this info, it has really helped, it didn't even have vacuum lines attached to carbs 2+3! I will rebuild the petcock as recommended enos and thanks for that great pic emw, I will be fixing this tomorrow! Take care, Noel
labadida is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
Battle between GS500E/NINJA500R? BigK General Sportbikes 29 09-26-2007 01:15 PM
Please help with fel line routing 1986 ZX-600R! labadida ZX-6R 0 03-22-2007 09:50 PM
Race Gas 2002 Busa SE On The Track 21 09-30-2004 02:25 PM
How-To's: When you first get your Pocket Bike Mr. Lesbian Pocketbikes 0 08-31-2004 04:21 PM
92 Ninja 600r Fuel line routing??? Diesel1 Help Me Fix It 1 07-14-2004 10:13 PM
You may post new threads
You may post replies
Refbacks are Off
