Sportbikes.net
Sportbikes.net (https://www.sportbikes.net/forums/)
-   GSX-R600 (https://www.sportbikes.net/forums/gsx-r600/)
-   -   GSX-R600 General Info Thread (https://www.sportbikes.net/forums/gsx-r600/562-gsx-r600-general-info-thread.html)
Gixxer_Six2003 06-29-2004 01:12 AM
'01-'03
Reccomended oil: 10W-40 , most people use 15W-50 Red Cap Monil-1 or 15W-40 Rotella T
Oil Capacity:
3.0 US Quarts without filter change
3.3 US quarts with filter change
Brake Fluid: DOT-4 (only use Glycol Based, no silicone or petroleum stuff)
Fork Oil- 10 weight (SS-8)
Fork Oil Capacity: 17.8 oz, each leg
Coolant: Something compatible with an aluminum radiator, mixed 50/50 with distilled water.
Cooling system capacity: 3.2 US Quarts
Spark Plugs: NGK CR9E
Tires:
Front-120/70ZR17 (58W)
Rear-180/55ZR17 (73W)
_____________________________
I'll add more to this, and better organize it when I'm not sleepy.
CamaroGSXRss 06-01-2005 01:26 AM
thanks for the specs
srd240sx 06-13-2005 03:09 PM
Great info. How about 97-00 GSXR600? Same as 01-03? I'm interested in oil capacity and the weight of oil.
Also what oil filter are you guys using?
97gixxer600 04-01-2006 12:31 PM
ditto
yeah I am looking for the same answer myself. Anyone know?
xxxFast Glass 04-01-2006 11:59 PM
1996-2000
Oil Type: SAE 10W40
Oil Capacity:
2.7 US Quarts without filter change
3.0 US quarts with filter change
Brake Fluid: DOT-4
Fork Oil Capacity: 18.0 oz, each leg
Cooling system capacity 2.7 US Quarts
Tires:
gsxrisko70 05-17-2006 02:22 PM
I need the wiring daigram for an 03 gsxr600 VERY IMPORTANT !!!!
Please contact me through this site or on my personal email of [email protected]. Thanks and remember any and all help will be greatly appreciated.
jk750 11-17-2006 12:40 AM
Sorry this hasn't been updated in forever....
'04-'05
Specs
Engine: 599cc,4-stroke,four-cylinder, liquid-cooled, DOHC, 16-valve
Bore Stroke: 67.0 x 42.5mm
Compression Ratio: 12.5:1
Fuel System: Fuel Injection
Lubrication: Wet Sump
Ignition: Digital/transistorized
Transmission: 6-speed, constant mesh
Final Drive: #525 chain
Overall Length: 2055mm (80.9 in.)
Overall Width: 715mm (28.1 in.)
Overall Height: 1150mm (45.3 in.)
Seat Height: 825mm (32.5 in.)
Ground Clearance: 135mm (5.3 in.)
Wheelbase: 1400mm (55.1 in.)
Dry Weight: 161kg (354.9 lbs.), 162kg (357 lbs.) Ca. model
Suspension Front: Cartridge-type, coil spring, fully adjustable spring preload, rebound and compression damping
Suspension Rear: Link-type, gas/oil damped, fully adjustable spring preload, compression and rebound damping
Brakes Front: Dual hydraulic disc
Brakes Rear: Single hydraulic disc
Tires Front: 120/70-ZR-17
Tires Rear: 180/55-ZR-17
Fuel Tank Capacity: 17 liter (4.5 gal.)
Color: Blue/White, Yellow, Black/Silver, Red/Black :edit black/orange
jk750 11-17-2006 12:41 AM
'06-'07
Specs
Overall Length: 2040mm (80.3 in.)
Overall Height: 1125mm (44.3 in.)
Seat Height: 810mm (31.9 in.)
Ground Clearance: 130mm (5.1 in.)
Dry Weight: 161 kg (354 lbs) CA Spec: 162 kg (357 lbs.)
Fuel Tank Capacity: 16.5 liter (4.4 gal.) CA Model: 15.5 liter (4.1 gal.)
Color: Blue/White, Red/White, Black/Matte Black, Blue/Black
Gixxer_Six2003 11-17-2006 03:32 AM
what are you trying to say ? That I got lazy ? :banana
jk750 11-17-2006 12:03 PM
:lao
No, I did! Or we both did... Oh well, no one noticed.
YBlegal 12-12-2006 03:36 AM
just out of curiosity, whats the stock rear sprocket tooth count on a 00 GSX-R 600?
Endorphine 01-21-2007 04:24 AM
So what is the actually horsepower/torque #'s on the 04 - 05 600's?
xxxFast Glass 01-21-2007 02:07 PM
I believe its 45 with a 16 tooth front sprocket. 108 link 525 chain.
twocannons 03-04-2007 09:33 PM
What about plugs, air filter, oil filter PN's and such.
ghost_a* 03-05-2007 05:10 PM
hey jk750, when listing color schemes for the '04-'05, you forgot my scheme.
the 2004 GSX-R 600 is the only year with the black/orange paint scheme.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
