Sportbikes.net
Sportbikes.net (https://www.sportbikes.net/forums/)
-   EFI tuning and Engine Mods (https://www.sportbikes.net/forums/efi-tuning-engine-mods/)
-   -   Power commander 07' zx-6r (https://www.sportbikes.net/forums/efi-tuning-engine-mods/454633-power-commander-07-zx-6r.html)
KawiDuc1198S 06-15-2012 06:47 PM
Im looking for clear detailed installation instructions.
Power commander for 2007 Kawi ZX-6R
Also please provide your engine mods before and after dyno graphs.
A:)lso please do tell if you have the smog block off plates that makes a difference for tuning on the dyno...
Thanks! post away!
Papa Rocket 02-15-2013 11:23 AM
Dynojet.com has the instructions in the download section.
Smog block off plates are the ONLY way to go if you're going to use the dyno the right way to tune it. If you aren't going to use the a/f ratios to tune it and just play around looking for highest HP, you're wasting time and $ on the dyno in the first place. The block off's keep the a/f ratio's accurate as they don't allow any fresh air to be le into the system.
kartl 05-20-2013 07:43 PM
What is your current engine mod? Also what are you targeting for?
KawiDuc1198S 05-20-2013 09:15 PM
Fuxk it im taki. The bike to the master comander the man the professor ivans performance!!!!!
DynojetResearch 08-19-2013 04:21 PM
You can temporarily pinch the air supply hose for the AIS while on the dyno with a pair of hemostats. This is essential for getting an accurate AFR reading. All dyno operators should know this. The block-off plates will keep the AIS disabled permanently, which should reduce deceleration popping but does not change power/torque output.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
