07-15-2008, 11:38 PM
#1 (permalink)
Casino Cash: $3304
Sportbike: 08 ZZR600 Kawasaki
front turn signals
Ok I'm new to this site and tried the search feature but didn't see any info that seemed to help , anyway what I want to know is how to gain access to the front signal for swapping out , I hate the big factory ones , and I didn't feel like just start pulling all the front plastics to find how to get to them. Thanks for any help and feel free to offer suggestions on the easiest way to find info on this site also.
Tommy
07-16-2008, 12:52 AM
#2 (permalink)
Casino Cash: $2119
Sportbike: 08 zzr6
I had to take off my front upper to get them unplugged from the electrical but you can take the old ones off through the little holes on the inside of the fairing by the front tire with a phillips s/d without taking them off. You could prolly just tap into the wires from there without taking any off but i didnt because I'm anal about wiring and had to make it right. I used LP smoked flushmounts on my 08.
Good Luck
I HOPE YOU DON'T F*** LIKE YOU RIDE OR YOU'LL NEVER GET IT IN
07-16-2008, 03:53 PM
#3 (permalink)
Casino Cash: $3304
when you say through the hole , dose that area with the Phillips screw actually opens , I looked at that and tried , but didn't want to force anything ,thanks.
07-16-2008, 04:12 PM
#4 (permalink)
MODERATOR
Location: Originally from Atlanta GA. Live in Milan, Indiana
Casino Cash: $69113
Sportbike: 2004 ZZR1200 2006 ZZR600 2008 Ninja250R
The front turn signal boots can be taken off be hand. You can remove the signal lamp "washer" parts 92200 and 92200B with a phillips head screwdriver. If your going to install flush mount turn signals on the front some require removing the upper cowling assembly. Reason? Because some types like MOTOTECK are like a sandwich and the hardware is on the inside. You have to remove the upper cowling assembly so you can get to that hardware to properly install the signals.
Please the exploded diagram for parts 92200 and 92200B that I mentioned. Jay
Click the image twice to make it larger.
SBN KAWASAKI FORUM MODERATOR
USAF VETERAN 1984-1997 SUPPORT OUR TROOPS THEY ARE THE REASON YOU ARE FREE TO RIDE THE OPEN ROADS OF THIS GREAT COUNTRY THE ANSWER GURU The 2005-2008 ZZR600 are exactly the same except for paint color. Having trouble finding parts for your 2005-2008 ZZR600? Try searching for parts that will fit a 2000-2002 ZX6R "J" model.
The 2005-2008 ZZR600 has one gas tank! It holds a total of 4.8 gallons of which 3.7 is available until you have to switch to reserve to use the remaining 1.1 gallons of gas.
07-16-2008, 11:16 PM
#5 (permalink)
Casino Cash: $3304
thanks for the diagram , will have to just tear into I see now  oh well may wait till I need to do a oil and filter change .
07-16-2008, 11:51 PM
#6 (permalink)
Casino Cash: $2119
Sportbike: 08 zzr6
Yea my LP flushmounts took me taking the front off to hold the back plate on but I just used the threaded plate from the stockers turned sideways as the backer plate instead of drilling new holes in my fairing for the mount screws. Also if your courdinated you wont have to take any plastics off for your oil change just put something in the bottom of your fairings to catch any oil that leaks from your oil filter during removal. I used a plastic bag wrapped around a piece of cardboard to channel it into my drain pan. Hope we could help.
07-17-2008, 10:43 AM
#7 (permalink)
Casino Cash: $26776
Sportbike: 2006 Silver ZZR600
I never really understand the hesitation to take off the fairings. It takes me about 1 minute per side. Cordless drill plus cut down allen wrenches and a screwdriver attachment.
Dynojet Kits for 05-08 ZZR600s are not the same as 00-02 ZX6Rs, if you put one on go read the directions for a ZZR and order the correct parts
Mods
Yoshimura RS-3 bolt on, +4 ignition advancer, Dynojet Stage 1 for ZZR, K&N filter, fuel mixture 3 1/4 turns, Iridium plugs, KCA removed
07-17-2008, 12:52 PM
#8 (permalink)
DIG OUT YOUR SOUL
Casino Cash: $6111
Sportbike: '05 Kawy Zzr600
I agree, don't fear your fairings. Even if you don't work on your bike, they must come off occasionally and someone else will do it anyways. You may as well do it yourself and know how it works.
2005 CRF 450r
1989 JS 550
I miss the two-stroke!
07-17-2008, 01:30 PM
#9 (permalink)
Casino Cash: $3304
I have no trouble working on the bike , for the most part , just had already had the ass end tore down and didn't feel like jumping on the front yet ,I may change my mind on the signals I put in anyway , I currently have some short stalk LED's but am looking at the LED flush mounts from LP  ,has anyone here tried and like them?
07-18-2008, 03:53 AM
#10 (permalink)
Casino Cash: $2119
Sportbike: 08 zzr6
Mine aren't LED but the LP flushmount 2's are pretty good I've had them on all three of my bikes with no troubles except I had to go back to LP to get bulbs cause no parts store carried them and they had no numbers on them. I stayed away from LED ones cause I did'nt want to install a load balancer to make them blink right.
07-18-2008, 10:36 AM
#11 (permalink)
Casino Cash: $8108
Sportbike: 2008 ZZR600
Check out Greggs Customs if you ever decide to replace the stock turn signals.
They're kinda pricey but look amazing.
07-19-2008, 05:12 PM
#12 (permalink)
Casino Cash: $3304
Well I ended up going by Cycle Gear today and got a set of these
I hope the turn out nice ,actually the ones I found were the Smoked lens but still have amber lighting.
07-22-2008, 07:18 PM
#13 (permalink)
You know, that guy
Casino Cash: $473
Sportbike: 07 kawasaki zzr600
smoked signals
07-23-2008, 09:14 AM
#14 (permalink)
Casino Cash: $2119
Sportbike: 08 zzr6
Those look like mine but mine are the smoked ones, and I know she needs washed.
07-23-2008, 06:05 PM
#15 (permalink)
Casino Cash: $1153
Sportbike: 2006/Kawasaki/ZZR
How bright are those compared to stock. I was thinking bout ordering them myself.
| Thread Tools |
| Display Modes |
Linear Mode
