SportbikeTrackGearJardineProducts.comSoupy's PerformanceMotoworld IncAnnitori DistributingMotorcycle.com Classifieds!AdvanstarMotorcycleShowsBritish Motorcycle GearGravesMotorsportsSee your ad here!
Old 11-07-2009, 12:45 PM   #1 (permalink)
woggies
Casino Cash: $3771
Sportbike: 2008 zzr600
woggies is on a distinguished road
Default first bike, winter advice...
Hello,
I have a zzr600 which is my first bike. I will be keeping covered in a shed for approx 3-4 months. The manual says to do an oil change and spray the metal with WD40.. and to drain the tank.
I was planning on pulling the battery and keeping the tank full with STABIL. and just doing a oil change in spring when I take it back out. Current oil has approx 1.5k on it.
Any advice? Do I need to spray the metal to prevent rust?
Also, do I need to put the tires on stands, or can I just put a blanket or something underneath of them?
Thanks for the help!
woggies is offline   Reply With Quote
Old 11-07-2009, 04:14 PM   #2 (permalink)
SundayDriver
Viva La Nation
SundayDriver's Avatar
Casino Cash: $26934
Sportbike: 2007 Kawasaki ZZR-600
SundayDriver is on a distinguished road
Make sure that your tank is full of gas. If you have stands use them, they're to prevent the tires from becoming flat on one surface. Make sure you change the oil before and after storage. Also try to get out and start it every so often.
SundayDriver is offline   Reply With Quote
Old 11-07-2009, 08:33 PM   #3 (permalink)
tober113
Casino Cash: $3995
Sportbike: 03 Yamaha R1 08 Kawi zzr600 09 Kawi 250r
tober113 is on a distinguished road
I would have to disagree. Starting it up every so often (unless you are riding it and have it up to full operating temp) will cause unwanted condensation in your carbs...or oil.. or something which is worse than letting it sit. Do everything else but let it sit untill you get it ready to ride in the spring.
correct me if I am wrong. I am obviously no expert.
this link might help Motorcycle Storage Tips
tober113 is offline   Reply With Quote
Old 11-08-2009, 06:51 AM   #4 (permalink)
ZZRrocket
MODERATOR
ZZRrocket's Avatar
Location: Originally from Atlanta GA. Live in Milan, Indiana
Casino Cash: $59366
Sportbike: 2006 ZZR600 2008 Ninja250R
ZZRrocket is on a distinguished road
Ahhhh it's the good old "what do I do to my bike for winter storage thread"!
This subject has numerous threads already in place.
*Change the oil and filter
*Insure the fuel tank is full and add Stabil to the Gas, run the engine to insure the Stabil makes it the carbs.
*Plug in the Battery Tender or you will have a dead battery in the spring.
DO NOT START THE BIKE EVERY ONCE IN A WHILE LEAVE IT ALONE!
I put my bike on stands. but that's a personal preference.
Get a dust cover style cover, not one made for storing the bike outside. They will hold moisture if you are storing the bike in an unheated garage. I use a flat queen size bed sheet as a dust cover.
SBN KAWASAKI FORUM MODERATOR
USAF VETERAN 1984-1997 SUPPORT OUR TROOPS THEY ARE THE REASON YOU ARE FREE TO RIDE THE OPEN ROADS OF THIS GREAT COUNTRY THE ANSWER GURU The 2005-2008 ZZR600 are exactly the same except for paint color. Having trouble finding parts for your 2005-2008 ZZR600? Try searching for parts that will fit a 2000-2002 ZX6R "J" model.
The 2005-2008 ZZR600 has one gas tank! It holds at total of 4.8 gallons of which 3.7 is available until you have to switch to reserve to use the remaining 1.1 gallons of gas.
ZZRrocket is online now   Reply With Quote
Old 11-08-2009, 09:12 AM   #5 (permalink)
woggies
Casino Cash: $3771
thanks everyone, I already put stabile in the gas (2oz) and filled the tank. I will change the oil next week.
The main thing I amunsure about is.. do I need to spray the metal parts (eg. frame) with oil or WS40 to prevent rust? I'm storing in an unheated shed
Old 11-08-2009, 09:45 AM   #6 (permalink)
ZZRrocket
MODERATOR
ZZRrocket's Avatar
Casino Cash: $59366
The frame is powder coated it's not going to rust. I have had my 2006 ZZR since October of 2005 and have stored it for four winters so far in an unheated shed at my in-laws and for two wintered in the unheated garage at my house with no issues. If the bike is clean and dry and covered in the storage place, then rust shouldn't be an issue.
I lived in Delaware for 11 years before moving to Indiana, it's that cold in Delaware that you can't still ride. I use to ride sometimes all the way until the end of December weather permitting. It was 72 here yesterday and going to get up to 69 today with loads of sunshine. Don't you think the Stabil was a little premature? Go ride! That's what I'm getting ready to do as soon as I finish typing this. SEE YA!
Old 11-08-2009, 10:17 AM   #7 (permalink)
Ramrodthrusterpuppy
Ramrodthrusterpuppy's Avatar
Casino Cash: $13797
Sportbike: 2008 Kawasaki ZZR600 (gone, but not forgotten) Suzuki GSXR 750 K9 Back In Black
Ramrodthrusterpuppy is on a distinguished road
The frame is also aluminum.....so it won't rust.
As everyone else has mentioned...oil change, full tank with fuel stabilizer and run it through. Personally, I pull the battery and then trickle charge it once a month. I also clean the chain and lube it as well...keeps the o-rings from drying out over the cold months.
IMO, at least use a rear stand if not both....or worst case rest the tires on pieces of wood versus sitting on a concrete floor. Concrete and cold weather can dry tires out over time weakening the belts and causing flat spots.
I also clean my bike from top to bottom before storage....road crud can harden over Winter and be impossible to clean off in the spring.
Ramrodthrusterpuppy is offline   Reply With Quote
Old 11-08-2009, 11:43 AM   #8 (permalink)
woggies
Casino Cash: $3771
Thanks, its in a shed with wood floor, so do I still need stands? I've read if you put the tires on blankets or something that they won't get flat spots???
Also, what kind of oil should I put in and should I change it again in spring?
Old 11-08-2009, 01:10 PM   #9 (permalink)
SundayDriver
Viva La Nation
Casino Cash: $26934
Mine's always been in a heated environment, so my winterizing is also a little bit different.
Old 11-08-2009, 05:04 PM   #10 (permalink)
Ramrodthrusterpuppy
Casino Cash: $13797
Should be OK. Not sure about the blankets, but the goal is to keep the cold from drying out the rubber. I also air down the tires a bit prior to storage...air shrinks in the cold.
Personally, I put in the cheapest oil & filter that I can find for Winter storage. Then in the Spring I run it a bit then change it out again to my regular oil & filter.
Old 11-08-2009, 09:16 PM   #11 (permalink)
ZZRrocket
MODERATOR
ZZRrocket's Avatar
Casino Cash: $59366
Tires aren't really a big deal to me since I change them over to a new set in late Febuary, I normally start riding again in mid to late March. So instead of waiting until spring like everyone else to get tires or service done I do it or have it done in the winter.
Old 11-09-2009, 08:15 AM   #12 (permalink)
PorkCereal
PorkCereal's Avatar
Casino Cash: $16126
Sportbike: 06 KAWI ZZR 600
PorkCereal is on a distinguished road
Move to fla where you can ride all year. Problem solved. O wait, flat straight roads. Nevermind. lol
PorkCereal is offline   Reply With Quote
Old 11-09-2009, 07:17 PM   #13 (permalink)
tober113
Casino Cash: $3995
thats when California sounds nice.
Old 11-09-2009, 11:07 PM   #14 (permalink)
rockscaler
rockscaler's Avatar
Casino Cash: $7551
Sportbike: RSV1000R, zx9r, zx7, vt500c, vn750, vn1500 Sold: cb250, 2 kz650s, ex500
rockscaler is an unknown quantity at this point
just ride it every week for an hour or 2 , problem solved
It is good to have an end to journey toward, but it is the journey that is important, in the end.
rockscaler is offline   Reply With Quote
Old 11-10-2009, 08:18 AM   #15 (permalink)
PorkCereal
PorkCereal's Avatar
Casino Cash: $16126
Get a set of winter studded tires like they did on SuperBikes and have fun this winter.
New! Any Advice? JulesAZ Women Riders 26 10-07-2009 04:14 PM
Hello! New to riding - Advice?? JulesAZ Arizona 62 07-11-2009 07:35 PM
Fitness advice for men...advice needed. Parabellum Open Forums 123 12-07-2007 05:14 PM
Legal Advice (not motorcycle related) MC_jr Busted!! I need Legal Advice! 19 07-06-2007 05:21 AM
Storing your bike over the winter? gr82av8 General Sportbikes 13 08-27-2004 03:20 PM
